Arggh, weakness of reminder for every Task recurrence
Outlook 2016 64 bit
In Outlook (desktop, v. 365/2016) I create a task for recurring items with Control-shift-K for next Tuesday.
I go alt-M for a reminder at some time, let's say at 11:45 A.M. next Tuesday.
I create recurrence (alt-H,E), daily, no end date.
Now if I am not mistaken, when the reminder is dismissed, you no longer have a reminder. But I want a reminder for each recurrence. 15 minutes before each, in fact. And if I dismiss one, there should be a new one tomorrow. But it appears that when you hit dismiss, the reminder is purged from the item, right? Surely they didn't leave that remedial item out? (BTW I've already extensively analyzed repeated daily snoozes and it fails in several respects)
I read Recurring Tasks don’t remind me again after the first occurrence - MSOutlook.info suggesting "mark as complete". Couple of problems, though: I now have a "crossed out item" which is confusing since it's still alive in the future; I have to remember to never ever dismiss, only right click it; but more than that, if I have a daily recurrence, and if I had a reminder at 11:45 A.M. on Tuesday that I marked complete, would it actually even know that 11:45 Wednesday is the next one? Or would it undesirably add 24 hours to the time of "mark complete"? (And on testing, not only is the reminder now unchecked, but recurrence is grayed out too.) (BTW How to Create Repeating Outlook Tasks and Reminders seems to be a nearly identical article)
Thank you for all you do here - so generous and awesome. Sorry that their ineptness makes me so furious. I initially composed an extensive explanation of the insane amount of work it seems to workaround, and why the feature is needed, and how a defective chimpanzee could program it correctly; but I pared it down to throwing up this prayer that there actually IS the capability, even famously buried by the interface geniuses...
...Or maybe I just need to accept that Tasks are too spazzed, but Appointments handle it properly? If I must go VBA I can, noting your "Send an email when an Appointment reminder fires" Send an Email When a Reminder Fires . That is an extremely well done, thorough article, though I'm grashing teeth that it was even needed.
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
V Accepted meetings do not get the default reminder Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
F how do i set a reminder in onenote 2010 Using Outlook 8
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
O Reminder due end of August is showing up now Using Outlook 2
L Calender reminder emails Using Outlook 3
S Reminder Dialog Open Button Using Outlook 2
F Set (flagged) reminder for next business day Using Outlook 4
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Open a Webpage When a Task Reminder Fires Using Outlook 0
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
M Messages in Outbox reminder is wrong Using Outlook 4
M Send an Email When a Reminder Fires Outlook VBA and Custom Forms 1
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send an Email When a Reminder Fires Using Outlook 0
A reminder for every 15 working days Using Outlook 11
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
Diane Poremsky Receive a Reminder When a Message Doesn't Arrive? Using Outlook 10
F e-mail reminder for shared calendar Outlook VBA and Custom Forms 1
K VBA - Prompt for reminder date time Outlook VBA and Custom Forms 7
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
rc4524 Create auto follow-up reminder email for already sent messages Outlook VBA and Custom Forms 1
smokiibear Share Office 365 Tasks such that Other Users also Are Alerted with Reminder Using Outlook 1
J Change reminder times of future appointments Using Outlook 1
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
S Pop up reminder while i close outlook Outlook VBA and Custom Forms 5
H Create a Task by Draft-EMail > Task+Reminder not Working Outlook VBA and Custom Forms 1
D Outlook 2007- old reminder popups Exchange Server Administration 4
2 Email not replied to reminder - aka boomerang? Using Outlook 3
R Problem with Reminder appearing in Inbox Using Outlook 5
J Reply All and No attachment Reminder Using Outlook 14
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
C Change default reminder time for contacts Using Outlook 2
