Customized ribbon and entries disappeared
witzker
I moved from Office 2010 to Office 2019
I copied the whole Outlook with MoBackup (Outlook Backup: Daten sichern von Outlook 2019, 2016, 2013, 2010 und 2007 sowie aus Office 365 (mobackup.de))
to the new PC with Office 2019.
Everything was fine.
Then I changed the zoom factor to custom 105 % in Windows 10.
After restart the old customized ribbon of my contact form was seen for a moment then switched to standard.
All my customizations in the settings of the ribbons are gone. ( but only in Kontacts)
After resetting the back zoom to 100% the ribbons are resented and all customization is still lost.
Is this a bug?
The ribbon settings must be somewhere in the registry?
What can I do to get my customized contact Ribbons back
witzker Customized Ribbon lost every now and then Using Outlook 3
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
G Flag for Follow Up with a customized duetime Using Outlook 1
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
mikolajek Add on for customized flag operations? Using Outlook 4
B Mass customized emails sent weekly Using Outlook 0
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
S Outlook 2013 - Customized auto-reply message Using Outlook 10
H Date options on Customized Contact form Using Outlook 2
A POST customized as a form Using Outlook 2
G Customized field data problem BCM (Business Contact Manager) 4
B Opening a saved Outlook customized form the same folder Using Outlook 2
B Opening a saved Outlook customized form after moving it to another folder Using Outlook 2
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
B Customized Send button Outlook VBA and Custom Forms 5
S Display SharePoint document library in a customized Outlook form Outlook VBA and Custom Forms 1
T Customized Sensitivity Levels Outlook VBA and Custom Forms 3
U Customized Command Button Outlook VBA and Custom Forms 3
W Ribbon XML customization Using Outlook 4
M Simplified ribbon missing Using Outlook 3
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
I Retention policies on outlook 2016 ribbon Using Outlook 2
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT Using Outlook 0
M No Show Group on ribbon Using Outlook 8
I Ribbon buttons grayed-out in Outlook 2013 Using Outlook 2
B How can I adjust the ribbon width? I want to see all of my Quick Steps. Using Outlook 1
piusg 2013: Place custom view on the ribbon Using Outlook 3
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
R Can I create custom subgroups on the ribbon? Using Outlook 5
M missing iCloud tab on ribbon bar Using Outlook 0
G Adding 3rd-Party Add-In to Home Ribbon in Outlook 2010 Using Outlook 1
E Outlook Ribbon Customization and Deployment Using Outlook 1
C Outlook Calendar Ribbon with iCloud Using Outlook 2
S ADD-IN Ribbon Missing Using Outlook 2
S ADD-IN Ribbon Missing Using Outlook 5
S Outlook 2010 Ribbon - Creating Links To Websites or EXE Files Using Outlook 4
M Move 'Reply All' on Ribbon in Outlook 2010 Using Outlook 2
L Email button on ribbon defaulting to exchange when POP is default Using Outlook 7
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
J Executing Ribbon Command from Code Outlook 2010 Outlook VBA and Custom Forms 3
T Word 2007 add-in ribbon icons greyed out Outlook VBA and Custom Forms 1
K add a designed group into a existing inspector ribbon Outlook VBA and Custom Forms 7
