Outlook 2019 is cutting Picture Extension *.pn_
witzker
I noticed that OL 2019 is cutting the extension *.png to *.pn_
This also happens with *pd_ instead of *.pdf
How to change this behaviour
witzker
THX
I use Kaspersky total security
settings
then
there you can set what you need e.g.
That's the one... disable email scanning. It won't fix attachments already downloaded though, only future attachments.
You can either save the attachment and fix the extension or save one, right click on it and choose an 'open with' app, so in the future all .pd_ will open. (I would still disable email scanning - regular scanning will pick up any infected document if you try to open them.)
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
H Outlook 2019 intermittent search results Using Outlook 0
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 8
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
A Outlook (and Office) 2019 Logging Using Outlook 2
witzker Open Contact missing in Outlook 2019 Using Outlook 2
C All Gmails don't show in Outlook 2019 Using Outlook 2
J How do I disable advertising in Outlook 2019? Using Outlook 15
R Outlook 2019 Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
A force outlook to default to MY calendar Using Outlook 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
A Outlook Reminders not populating for certain events Using Outlook 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
hstein POP3 latest Outlook Using Outlook 0
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
F Moving Outlook to new PC Using Outlook 0
