White square in body of Outlook Messages (O2016 Version 2012 32bit Click To Run)
MOutlook
I suspect this is a display driver issue (refresh, redraw). New computer, sometimes getting a large white screen obscuring a section of messages, and this stays in place when scrolling down, and also changing between inbox and sent items.
All my display drivers are up to date (also Windows and Office updates).
has anyone else experienced this? (screen shot attached). It appears to be an intermittent fault.
MOutlook
I am hesitant to do an office repair, as it is a new installation on a new computer, and everything seems to be working OK (apart for this occasional white square).
Restarting Outlook seems to resolve the issue. Restarting Outlook also seems to result in the issue (when it has not been occurring in the previous session).
Vincenzo
Try toggling the Hardware Graphics Acceleration Setting, in Outlook, shown below
Vincenzo
To clarify, when i say toggle, I mean if it's on turn it off. If it's off, turn it on.
T screen freezes, then turns white Using Outlook 2
Christina Garcia Outlook 2010: Two incomings in white text Using Outlook 2
I Pound Symbol in emails show as � (black diamond with white question mark inside) - Office 2010. Using Outlook 11
P Outlook 2013 not showing little colored square as to peoples availability Using Outlook 5
C Re: Outlook 2007 is showing all pictures as a blank square Using Outlook 2
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Forwarding email and replacing body Outlook VBA and Custom Forms 1
M Want to autorespond to an email address in the body of message Using Outlook 0
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
S Default Font in body of Task Using Outlook 0
oliv- GetTable Add body Outlook VBA and Custom Forms 4
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
J Increase font size of message body Using Outlook 5
