Replyall macro with template and auto insert receptens
Madsfrost
Outlook 2019 64-bit
Hello !
I am trying to "merge" the Automatic insert receptens name and replyall with template macro.. What am i doing wrong ??
Im trying to merge theese 2. They work seperately. But after adding the autoinsert names to field the Replyall macro with template wont add the item.
GOAL: Is that the Replyall with template macro auto inserts Name of the sender in the Text field "Hello <Name of sender>
Auto insert names to field macro:
Option Explicit
Private WithEvents oExpl As Explorer
Private WithEvents oItem As MailItem
Private bDiscardEvents As Boolean
Dim oResponse As MailItem
Set oExpl = Application.ActiveExplorer
bDiscardEvents = False
Private Sub oExpl_SelectionChange()
Set oItem = oExpl.Selection.Item(1)
' Reply
Private Sub oItem_Reply(ByVal Response As Object, Cancel As Boolean)
Cancel = True
bDiscardEvents = True
Set oResponse = oItem.Reply
afterReply
Private Sub oItem_Forward(ByVal Response As Object, Cancel As Boolean)
Cancel = True
Set oResponse = oItem.Forward
afterReply
Private Sub oItem_ReplyAll(ByVal Response As Object, Cancel As Boolean)
Cancel = True
Set oResponse = oItem.ReplyAll
afterReply
Private Sub afterReply()
oResponse.Display
' get the recipient names
Dim R As Outlook.Recipient
Dim i
Dim strTo As String, strCC As String
Set Recipients = oResponse.Recipients
For i = 1 To Recipients.Count
Set R = Recipients.Item(i)
Debug.Print R.Name, R.Type
If R.Type = olCC Then
strCC = R.Name & ", " & strCC
strTo = R.Name & ", " & strTo
'insert the names
Dim olInspector As Outlook.Inspector
Dim olDocument As Word.Document
Dim olSelection As Word.Selection
Set olInspector = Application.ActiveInspector()
Set olDocument = olInspector.WordEditor
Set olSelection = olDocument.Application.Selection
olSelection.InsertBefore "CC: " & strCC
olSelection.InsertParagraphBefore
olSelection.InsertBefore "To: " & strTo
Sub Bookingnyordre()
Dim origEmail As MailItem
Dim replyEmail As MailItem
Set origEmail = ActiveExplorer.Selection(1)
Set replyEmail = CreateItemFromTemplate("\\alserver\dataalle\Kundeservice\Hurtigsvar makrotekster\Booking ny ordre.oft")
replyEmail.To = origEmail.Reply.To
replyEmail.CC = origEmail.CC
replyEmail.HTMLBody = replyEmail.HTMLBody & origEmail.Reply.HTMLBody
replyEmail.SentOnBehalfOfName = "kundeservice@autologik.dk"
replyEmail.Recipients.ResolveAll
replyEmail.Subject = origEmail.Subject & " Din ordre er nu booket"
replyEmail.Display
Set origEmail = Nothing
Set replyEmail = Nothing
See attached error
Diane Poremsky Reply or ReplyAll with Attachments Using Outlook 0
R ReplyAll Outlook VBA and Custom Forms 1
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
G VBA Macro Using Outlook 4
