Favorites for People/Contacts?
LoztInSpace
Outlook 365/Exchange via MS Office subscription
Windows 10 Desktop
Is there a hack to setup a Favorites folder for People/Contacts similar to the Favorites folder in email?
Using categories, I have setup a Favorites view, but switching views back and forth requires too many keystrokes and is a cumbersome process.
(I remember older versions of Outlook that allowed definition of radio buttons in the left pane to switch between views :()
You want to apply custom views to the folder? The only shortcut would be a macro to apply it. You can put a macro button on the ribbon for each view.
L Favorites don't update Using Outlook 1
G Favorites panel entries move around after restarting Outlook 2016 Using Outlook 1
M New Message Indicator in Favorites Using Outlook 2
T Recovering Favorites From Exchange Exchange Server Administration 4
D Not enough room in Favorites Using Outlook 1
Kristine RS box added in Favorites disappears Using Outlook 6
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
Commodore Favorites vs. Shortcuts Using Outlook 1
M Automatically highlight unread mail in Favorites inbox(s) (Blue number) Using Outlook 1
P Problem: Favorites not persisting. (Oulook 2010) Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
GregS Exporting contacts Using Outlook 1
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
E GAL Attributes to Contacts Using Outlook 0
L Merge two contacts folders Using Outlook 1
N Gathering Calendar Appointments from Calendars that synced as Contacts Exchange Server Administration 1
W Migrating Outlook 365 Contacts & Calendar Using Outlook 2
