Changing colors of today's appointments, but not recurring ones
schwarznavy
Using conditional formatting, I can change the colors of today's appointments by using the criteria "Starts" and setting to today. For some reason, that also affects any and all recurring appointments. Why?
I can add an additional criteria of "reccuring = no" but then that removes any recurring appointments for today.
Is there a way to apply conditional formating to only and all of today's appointments?
Recurring appointments are weird - the recurrence pattern makes it seem like it should be on every day within the recurrence period, so start filters fail. If you don't have a ton of recurring events, don't worry about it. If you have a lot, add recurring no - they'll still be on the calendar, mixed with the other highlighted appointments.
Also, Conditional formatting won't work on appointments that have categories.
schwarznavy
Thanks Diane. I knew about "recurring no" but I do have lots of recurring appointments. The mixture of formatted and non-formatted colored appointments doesn't sit well with me.
A tangent -- still upset that I can't get conditional formatting on the To-Do Bar Calendar!
schwarznavy
Diane - as an alternative - I'm thinking to automatically categorize appointments based on "Show As" status. I found your script on categorizing appointments based on subject here: How to Auto Assign a Color Category to New Appointments via Outlook VBA
First, the script throws me a compile error when I startup Outlook. The "WithEvents olItems As Outlook.Items" is highlighted and it says "Invalid attribute in Sub or Function."
Unfortunately, I'm starting to learn javascript but haven't gotten around to VBA. Once I can get past that error, I figure I will play around with the .busystatus property (AppointmentItem.BusyStatus property (Outlook)) instead of subject...
schwarznavy
Actually, figured it out.
I already had macros. At the top there were already several "WithEvents" lines. So I moved yours to the top. I changed Public to Private. Also, I already had a section with Application_Startup(). I moved the olItems line into that. Now it works based on subject.
schwarznavy
Follow-on -- using Select Case Item.BusyStatus works, following the constants returned (BusyStatus Property (AppointmentItem Object)).
Now I'd like to make it work whenever I change an appointment's busystatus. For example, I saved it earlier set to "Busy" but then later I change it to "Tentative."
schwarznavy
Oops. That wasn't your script. I had too many window up!
Color categories, yes, formatting - no. But Tasks can be filtered and formatted. :)
Is the macro in ThisOutlookSession or in a module? WithEvents goes at the top of thisoutlook session.
Yeah. :) That is exactly what you needed to do. The public and private stuff doesn't usually make a difference - unless you have two macros with the same name in different modules. Then private can only be called by other macros in that module.
You can watch the folder and when a new item is added, set a category if the status is busy.
there is an example here to watch for changes and do something -
It's doing a look up in another calendar - so I guess it not a good example. :)
Not tested - and you need to set the curCal object to the calendar you are watching.... but something like this should work.
Private Sub curCal_ItemChange(ByVal Item As Object)
if Item.BusyStatus = olBusy then
item.categories = "Whatever"
item.save ' may not be required
end if
schwarznavy
Private Sub Items_ItemChange(ByVal Item As Object) Dim Appt As Outlook.AppointmentItem If Item.Class = olAppointment Then Select Case Item.BusyStatus Case 2 Item.Categories = "Busy" Item.Save Case 3 Item.Categories = "Out of Office" Item.Save Case 1 Item.Categories = "Tentative" Item.Save End Select End If End Sub
Next - figure out how to not blow away any other categories that may be set on the items.
Would help if I could read. :) If you are just adding, use
item.categories = "new category" & item.categories
That should put it first - switch it to put the new one at the end:
item.categories = item.categories & "new category"
schwarznavy
I can't get it to work on changes, but it does work on new appointments. I basically duplicated much of the code for _ItemAdd and _ItemChange as follows. Any idea what I'm doing wrong? When I add an appointment - even if I've added a different category - the appropriate additional category will be added bepending on the BusyStatus. When I change an appointment's BusyStatus, there is no change of category.
Private WithEvents olItems As Outlook.Items
Private WithEvents olItem2 As Outlook.Items
    Set olItems = Session.GetDefaultFolder(olFolderCalendar).Items
Private Sub Initialize_handler()
    Dim Ns As Outlook.NameSpace
    Set olItems2 = Ns.GetDefaultFolder(olFolderCalendar).Items
Private Sub olItems_ItemAdd(ByVal Item As Object)
    Dim NewAppt As Outlook.AppointmentItem
        Set NewAppt = Item
            Case 2
                Item.Categories = Item.Categories & "," & "Busy"
                Item.Save
            Case 3
                Item.Categories = Item.Categories & "," & "Out of Office"
                Item.Save
            Case 1
                Item.Categories = Item.Categories & "," & "Tentative"
                Item.Save
Private Sub olItems2_ItemChange(ByVal Item As Object)
        Set Appt = Item2
            Case 2
                Item.Save
            Case 3
                Item.Save
            Case 1
                Item.Save
I have not had a chance to test your full macro - but this -
Set Appt = Item2
should be
Set Appt = Item
This is working to add the category once on changes - its using the olitems in app startup, not Initialize_handler - without the If lines, it added a ton of categories on change. But... you really need to remove the busy state category on changes, not add to it. But its a start.
Private Sub olItems_ItemChange(ByVal Item As Object)
            Case 2
            If InStr(Item.Categories, "Busy") = 0 Then
                Item.Save
            Case 3
            If InStr(Item.Categories, "Out of Office") = 0 Then
                Item.Save
            Case 1
            If InStr(Item.Categories, "Tentative") = 0 Then
                Item.Save
This is removing the old categories, if you changed the busy type.
Dim strCat As String
Dim arrCat As Variant
            Case 2
                Item.Save
             arrCat = Array("Out of Office", "Tentative")
            Case 3
                Item.Save
            arrCat = Array("Busy", "Tentative")
            Case 1
                Item.Save
            arrCat = Array("Out of Office", "Busy")
            Case Else
' remove the categories if not one of these
            arrCat = Array("Out of Office", "Busy", "Tentative")
   arr = Split(Item.Categories, ",")
For j = LBound(arrCat) To UBound(arrCat)
   Debug.Print arrCat(j)
    If UBound(arr) >= 0 Then
  ' Check for Category
    For i = 0 To UBound(arr)
    Debug.Print arr(i)
      If Trim(arr(i)) = Trim(arrCat(j)) Then
        ' remove it
            arr(i) = ""
            Item.Categories = Join(arr, ",")
Next j
    Item.Save
schwarznavy
Thank you Diane. I won't be able to test until I get back to work on Tuesday. But, quick question...with your suggestion above do I need to change any of the starting items, such as:
schwarznavy
Actually, I loaded Outlook at home and tested. It works great with just this
schwarznavy
I also switched the order of these:
to these:
Item.Categories = "Busy" & "," & Item.Categories
Since that puts my Busy/Tentative/O-o-O colors at the forefront, since the whole purpose of this was to give me better visual cues as to the BusyStatus of my appointments.
J Changing Colors or Font Styles on the Outlook Bar Using Outlook 1
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
M CHANGING ACCOUNT NAME Using Outlook 0
J Changing margins in received email display Using Outlook 3
B Automatic picture download and changing email addresses Using Outlook 3
L changing view settings based on message body Using Outlook 1
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
cimbian Changing default contact view Using Outlook 2
