Changing colors of today's appointments, but not recurring ones
schwarznavy
Next, I want to see if I can change "Private Sub olItems_ItemChange(ByVal Item As Object)" to only work if the BusyStatus changes, rather than if the appointment changes. Because there might be a time where I want to remove a Busy/Tentative/O-o-Office category manually in favor of some other category, and this script won't allow it.
The last macro I posted removes the category if the busy state is changed.
schwarznavy
Yes it did. Also, it forces a category of Busy, Tentative, or Out of Office even if I manually decide to remove that category.
I've done some research and tinkering and some rewrites that I think provide these extra functions:
- Automatically and Immediately assign category of "Busy" when creating a new appointment (immediately when the window opens, without having to save first.)
- Only add Busy/Tentative/Out-of-Office category if I change the BusyState ... i.e. Doesn't make a category change if I change an appointment's time, subject, or any other property.
- Makes those changes immediately when the BusyState changes (without having to save to see the category changed)
Not sure if this code works correctly to invitations I receive (can't test that at home since I don't get any invitations). Crossing fingers that I didn't make any snafus. Haven't seen any in my testing here at home.
Private WithEvents myInspector As Outlook.Inspectors
Private WithEvents Item As Outlook.AppointmentItem
    Set myInspector = Application.Inspectors
Private Sub myInspector_NewInspector(ByVal Inspector As Outlook.Inspector)
    If TypeOf Inspector.CurrentItem Is AppointmentItem Then
        Set Item = Inspector.CurrentItem
Private Sub Item_Open(Cancel As Boolean)
    If Len(Item.Subject) = 0 And Len(Item.Location) = 0 And Item.BusyStatus = 2 Then
       Item.Categories = "Busy"
Private Sub Item_Add(ByVal Item As Object)
    Select Case Item.BusyStatus
          Case 2
              Item.Categories = "Busy" & "," & Item.Categories
              Item.Save
          Case 3
              Item.Categories = "Out of Office" & "," & Item.Categories
              Item.Save
          Case 1
              Item.Categories = "Tentative" & "," & Item.Categories
              Item.Save
Private Sub Item_PropertyChange(ByVal Name As String)
    If Name = "BusyStatus" Then
        Dim strCat As String
        Dim arrCat As Variant
            Case 2
            If InStr(Item.Categories, "Busy") = 0 Then
            arrCat = Array("Out of Office", "Tentative")
            Case 3
            If InStr(Item.Categories, "Out of Office") = 0 Then
            arrCat = Array("Busy", "Tentative")
            Case 1
            If InStr(Item.Categories, "Tentative") = 0 Then
            arrCat = Array("Out of Office", "Busy")
            Case Else
            ' remove the categories if not one of these
            arrCat = Array("Out of Office", "Busy", "Tentative")
        arr = Split(Item.Categories, ",")
        For j = LBound(arrCat) To UBound(arrCat)
            Debug.Print arrCat(j)
            If UBound(arr) >= 0 Then
                ' Check for Category
                For i = 0 To UBound(arr)
                    Debug.Print arr(i)
                    If Trim(arr(i)) = Trim(arrCat(j)) Then
                        ' remove it
                        arr(i) = ""
                        Item.Categories = Join(arr, ",")
            Next j
            Item.Save
I don't think it will work with meetings - at least not new meetings - because of this:
The change macro should work with meetings.
schwarznavy
You are correct! Just got to work and tested it out. Everything works fine except meetings that I'm invited to.
schwarznavy
I seem to have achieved it like this:
Dim myMtg As Outlook.MeetingItem
    Set objAppointment = Inspector.CurrentItem
ElseIf TypeOf Inspector.CurrentItem Is MeetingItem Then
    Set myMtg = Inspector.CurrentItem.GetAssocitedAppointment(False)
    Set objAppointment = myMtg
Mostly seems to be working. I am seeing weird behavior as follows:
- If I set an appointment to busy/tent/outofoffice it categorizes fine
- If I reply to a meeting request as "Accept" or "Tentative" then it categories fine
- If I open any appointment or meeting on my calendar and then change to busy/tent/outofoffice it re-categorizes fine
- If I right-click on any appointment or meeting on my calendar and then change the BusyStatus it re-categorizes fine
- But, if I then right-click on a different appointment or meeting and then change the BusyStatus it will NOT re-categorize...
- But then if I open one and change BusyStatus it will be fine....
- and if I then right-click it will do fine.
So, right-clicking a second one in a row will not work.
schwarznavy
Actually, this weird behavior exists without the "MeetingItem" addition....
this has to do with inspectors and picking up the changed selection. I'm not sure if there is a way around it, short of not doing two in a row or opening the second one.
schwarznavy
Diane - this works on invitations I receive, but only if I double-click to open them first. In other words --
1. Receive invitation
2. Click accept or tentative from preview pane
3. Meeting accepted, but no categorization
2. Double-click invitation to open it
3. Click accept or tentative from the opened invitation
4. Meeting accepted, categorization works automatically according to the script
I will try your advice in here:
That is based on setting the appointment Private
schwarznavy
Should have been more clear. It shows me how to work off of items I double-clicked to open and/or those selected in the main window. By integrating parts of below into what we've already created, everything seems to work fine (except trying to change multiple items in a row from the calendar window):
Private WithEvents objInspectors As Outlook.Inspectors
Private WithEvents objExplorer As Outlook.Explorer
Private WithEvents objCalendarItem As Outlook.AppointmentItem
    Set objInspectors = Outlook.Application.Inspectors
    Set objExplorer = Outlook.Application.ActiveExplorer
Private Sub objExplorer_SelectionChange()
    If TypeOf objExplorer.Selection.Item(1) Is AppointmentItem Then
       Set objCalendarItem = objExplorer.Selection.Item(1)
Private Sub objInspectors_NewInspector(ByVal Inspector As Inspector)
    If TypeOf Inspector.currentItem Is AppointmentItem Then
       Set objCalendarItem = Inspector.currentItem
schwarznavy
Aha! Found another case where it doesn't work.
If I open or select an email, and then click the meeting button to "Reply All with Meeting", the script doesn't get triggered.
This script is already supposed to trigger on Explorer_SelectionChange; Inspectors_NewInspector; Appointment_Open, Appointment_Add, and Appointment_PropertyChange....so clearly converting a mailitem to an appointmentItem/MeetingItem is not triggered by one of those.
Any idea what event I can trigger off of having an email selected/open and hitting the meeting button?
J Changing Colors or Font Styles on the Outlook Bar Using Outlook 1
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 3
S Changing Message Class Outlook VBA and Custom Forms 4
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
M CHANGING ACCOUNT NAME Using Outlook 0
J Changing margins in received email display Using Outlook 3
B Automatic picture download and changing email addresses Using Outlook 3
L changing view settings based on message body Using Outlook 1
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
