Macro to extract and modify links from emails
schwarznavy
Good morning,
When coworkers create Skype for Business meetings in Outlook, the invitation includes a Skype Meeting link. I'm assuming that the recipient's Outlook client reads this link and therefore enables a "Join Meeting" button in numerous places (the ribbon, when right-clicking the meeting, the reminder window, etc).
Issue: When coworkers use a Virtual Meeting Room instead of a Skype meeting, the invitation includes a different kind of link (###-####@work.domain). Outlook clients don't read this at all. No "Join Meeting" buttons are activated. Clicking the link in the email opens up a new email to that address. To join via video, I need to dial #######@work.domain (remove the hyphen) in Skype and then join video.
Solution: I'm thinking a good solution would be to create a macro that can read any ###-####@work.domain links in emails. Then, it would convert that link to whatever is the appropriate URL to tell Skype to make a video call to the correct address. My guess is it is something like: sip:<#######@work.domain>.
Any other suggested paths?
Any tips or pointers for me to get started?
Sentinels
Outlook 2016 64 bit
Good morning,
I do something very similar - but in appointments (not e-mail) - for zoom. For me, it is triggered with any appointment that contains a zoom link (with a reminder 15 minutes before and a pop-up request to join 2 minutes before the meeting). Feel free to play around the code to work for new e-mails / skype:
Public WithEvents oReminders As Outlook.Reminders
Public sDismissSubject As String
Private Sub Application_Reminder(ByVal objItem As Object)
Dim objWordHyperlinks As Word.Hyperlinks
Dim objWordHyperlink As Word.Hyperlink
Dim iTimeDiff As Integer
Set oReminders = Outlook.Reminders
If objItem.MessageClass <> "IPM.Appointment" Then Exit Sub
If funcIsZoomAppt(objItem) Then
iTimeDiff = (objItem.Start - VBA.Now) * 24 * 60
If iTimeDiff <= 2 And iTimeDiff >= 0 Then
Set objWordHyperlinks = objItem.GetInspector.WordEditor.Hyperlinks
For Each objWordHyperlink In objWordHyperlinks
If VBA.InStr(1, objWordHyperlink.Address, "zoom.us/", vbTextCompare) Then
If VBA.MsgBox("Zoom appointment (" & objItem.Subject & ") in " & iTimeDiff & " minutes. Do you want to join?", vbYesNo + vbDefaultButton1, "Reminder") = vbYes Then
Call VBA.Shell("C:\Program Files (x86)\Google\Chrome\Application\chrome.exe " & objWordHyperlink.Address)
sDismissSubject = objItem.Subject
objItem.ReminderSet = False
objItem.Save
Exit For
Next objWordHyperlink
Set objWordHyperlink = Nothing
Set objWordHyperlinks = Nothing
ElseIf iTimeDiff > 2 Then
Call VBA.MsgBox("Zoom appointment (" & objItem.Subject & ") in " & iTimeDiff & " minutes.", vbOKOnly, "Reminder")
objItem.ReminderSet = True
objItem.ReminderMinutesBeforeStart = 2
objItem.Save
Function funcIsZoomAppt(objItem As Outlook.AppointmentItem) As Boolean
funcIsZoomAppt = False
If VBA.Left(objItem.Location, VBA.Len("https://[Redacted].zoom.us/j/")) = "https://[Redacted].zoom.us/j/" Then
funcIsZoomAppt = True
If VBA.InStr(1, objWordHyperlink.Address, "zoom.us/", vbTextCompare) And objItem.Subject <> "" Then
Exit For
End Function
schwarznavy
Hello Sentinels,
Just getting around to trying this out. Did you possibly leave something out?
I'm getting en error with that says "User-defined type not defined." The Visual Basic editors then pops up. "Private Sub Application_Reminder(ByVal objItem As Object)" is highlighted yellow, and "objWordHyperlinks As Word.Hyperlinks" is selected.
I will try to tinker with it.
miaturner95
Outlook 2019 64-bit
this can be quite handy, to filter out unnecessary links, especially in large group chats. I have found this link for something similar
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
G VBA Macro Using Outlook 4
