Modifying VBA script to delay running macro
Legaldeejay
Outlook 2019 64-bit
Hello:
I have the below code for Outlook 365 which will run a macro after sending an email. How do I modify this to delay the macro 10 seconds after clicking send, and how do I limit this code to my exchange account email which is the default email account? Thanks.
Option Explicit
With Item
Call BatchResendEmailsMacro
Do you want to delay the macro or delay sending the message? If you delay it, the macro may not work as the message is gone. You can watch the sent folder - this would allow the macro to apply only the sent folders you're watching.
Use an if statement to check the account or from address -
Dim oAccount As Outlook.Account
For Each oAccount In Application.Session.Accounts
If oAccount = "name of account" Then
'do whatever
End if.
Legaldeejay
Outlook 2019 64-bit
I want to delay the macro. I already have a rule which delays sending the message. Based on the above, what will the entire VBA Code look like?
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
I Outlook 2013 Modifying an Outlook calendar Using Outlook.com accounts in Outlook 0
M Modifying Macro MoveAgedMail(2) - use categories & "to" as variable Using Outlook 12
B modifying print template for printing out appointment details Using Outlook 2
S Automatically modifying an email Outlook VBA and Custom Forms 3
U Creating or modifying Outlook .Nk2 file in C# Outlook VBA and Custom Forms 1
A Expected behauvior when modifying properties? Outlook 2003. Outlook VBA and Custom Forms 3
J Modifying a Business Contact Manager Report BCM (Business Contact Manager) 1
