Visual indicator of a certain property or to show a macro toggle
schwarznavy
Greetings,
I am using a script very similar to the one posted here (Outlook VBA for marking a new mail as a task before sending) which sets a customer UserProperty on an email being written. Also, concurrently, the SentItems folder is being monitored and when it sees email with that property takes some actions.
While drafting an email, is there a way to show a visual indicator that a macro was run or that a custom UserProperty was set? Ideally, I'd have a button for the macro on the ribbon that visually indicates whether the button was pushed or not. Alternatively, is there a way to have a button or something that checks UserProperties and changes visually depending on the UserProperty?
Are you using an itemadd or adding it as the message form was opened?
You would need to use a custom toolbar to create a toggle button. I don't have any samples that do this though.
schwarznavy
Hi Diane. Yes, itemadd. While the message is opened, the macro adds a userproperty. Another script is looking for itemadd to the Sent Folder and when it sees an item added with that user property, it does some things.
The way I see it, the visual indication would have to either act on the userproperty existing, or triggering the macro.
Is there a way to make a custom form that looks for certain userproperties and changes visually when it sees one?
K Visual of Tasks on desktop Using Outlook 2
C Visual Basic auto create task from email including attachments Using Outlook 9
M How to Create Macro in Visual Basic to add Contacts from Personal Folder Using Outlook 4
E trust access to visual basic project greyed out in outlook 2003 Outlook VBA and Custom Forms 1
D Outlook AddIn can't load outside Visual Studio Outlook VBA and Custom Forms 1
T Deploying add-ins from Visual Studio Tools for Office Outlook VBA and Custom Forms 2
U Outlook Addin Creation using Visual Studio 2008 Outlook VBA and Custom Forms 1
M New Message Indicator in Favorites Using Outlook 2
Diane Poremsky New Message Indicator for Subfolders? Using Outlook 0
P Appearance (Width) of Calendar Appointment "Show as (Free/Busy/etc)" Indicator Using Outlook 1
A Outlook Reminders not populating for certain events Using Outlook 2
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
F How to show assigned tasks under certain mailbox? Using Outlook 4
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
J Autoforward emails to different contacts based on certain criteria using only one rule Using Outlook 1
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
P move a specified email "From" tag items to a certain folder whenever there is "New Mail" in the inbo Outlook VBA and Custom Forms 5
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
M Macro to Format certain words in email message Outlook VBA and Custom Forms 5
J Is there a way to disallow sending from certain addresses to specific email addresses? Using Outlook 2
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
M Rule to pop a warning dialogue on certain actions Using Outlook 1
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
K extract certain text from an Outlook Email Message Outlook VBA and Custom Forms 2
T Setting a Default Subject from a certain Signature Using Outlook 0
R Cannot open certain emails Using Outlook 3
J Restricting access to certain features for specific users BCM (Business Contact Manager) 3
X Can you get outlook to ignore certain weeks for recurring meetings? Using Outlook 1
M Why does my font size increases only when I reply to certain people? Using Outlook 3
H Automatic excel data added to Certain Emails that are received Using Outlook 3
Commodore Auto-formatting of certain phone numbers Using Outlook 2
E Outlook rule only active certain times of day Using Outlook 6
C Duplicate emails from pop but only for certain date range? Using Outlook 4
T Autorespond only to e-mails sent from certain domains: Using Outlook 2
C How do I hide distribution list from global contacts for certain users? Exchange Server Administration 1
M Can't send email to certain valid email addresses, message says Using Outlook 1
R Scanning E-mail for Certain words & changing the background Outlook VBA and Custom Forms 3
R How do I create a macro to put text in certain emails? Outlook VBA and Custom Forms 1
