Filter unread emails in a search folder vba help
Yousuf@WV
Hi I need help with filter all the unread emails in a search folder that is created using the VBA code below. Basically, I need to add the logic to filter out emails that are sent by internal people and forwarded messages. Please advise how do I accomplish this task. I am bit new to this so need some help. I will appreciate it. Thanks!!
Sub CreateSearchFolder_AllNotRepliedEmails()
Dim strScope As String
Dim strRepliedProperty As String
Dim strFilter As String
Dim objSearch As Outlook.Search
'Specify the folders to be searched
'Here we use Inbox folder for an example
strScope = "'" & Application.Session.GetDefaultFolder(olFolderInbox).FolderPath & "'"
'Search filter
strRepliedProperty = "http://schemas.microsoft.com/mapi/proptag/0x10810003"
strFilter = Chr(34) & strRepliedProperty & Chr(34) & " <> 102" & "AND" & Chr(34) & strRepliedProperty & Chr(34) & " <> 103"
Set objSearch = Outlook.Application.AdvancedSearch(Scope:=strScope, Filter:=strFilter, SearchSubFolders:=True, Tag:="SearchFolder")
'Save the search folder
objSearch.Save ("Not Replied Emails")
MsgBox "Search folder is created successfully!", vbInformation + vbOKOnly, "Search Folder"
Jennifer Murphy Spam filter not working Using Outlook 13
B Task Filter Not Working When I add too many criteria Using Outlook 0
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
G How to filter by the format of an email address Using Outlook 6
S Mail filter recieved before the last 2 working days Using Outlook 1
Liza Creating a rule in outlook to filter messages Using Outlook 0
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
Diane Poremsky Filter and Save Contacts to a CSV File Using Outlook 0
Fozzie Bear HomeTab Email filter "Greyed Out" in Outlook 2013 Exchange Server Administration 3
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
J Outlook VBA for Email Filter Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
M Filter today's mail Using Outlook 2
J Task Filter for Status OR One Month Using Outlook 4
R Filter Views by Category Using Outlook 2
D Junk Mail filter Using Outlook 1
S Filter by accounts but communicate to all linked contacts BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D How Would I Write This Filter? Using Outlook 3
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
williamlambton Filter which removes Display Names from incoming emails. Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
L Need a good email filter Using Outlook 2
P BCM Review & Filter BCM (Business Contact Manager) 1
M DASL Filter function? Outlook VBA and Custom Forms 3
M Today(S) function in DASL Filter Outlook VBA and Custom Forms 1
M Create search folder filter that converts UTC time to local? Outlook VBA and Custom Forms 9
A Junk mail filter is junk Outlook Wishlist 2
E DASL Filter doesn't work when defined programatically Outlook VBA and Custom Forms 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
K Can I filter by fields 'containing' specific words? BCM (Business Contact Manager) 1
P Custom rule to filter on sender name Outlook VBA and Custom Forms 5
M Filter rules to distinguish To and CC fields Outlook VBA and Custom Forms 1
