Save selected messages VBA does not save replies and/or messages that contain : in subject
numberonelevelit
Outlook 2019 64-bit
Hi all,
So please see the VBA code i'm using to save selected messages to a folder of my choice in Outlook. I noticed that whenever i try to save responded mails, it fails to save as an .eml file and just turns into a blank file (attached image). Messages that have been received come save with no challenges though. Please see code below, what am I doing wrong? This is really giving me stress.
Public Sub SaveMessageAsMsg()
'Update by Extendoffice 2018/3/5
Dim xMail As Outlook.MailItem
Dim xObjItem As Object
Dim xPath As String
Dim xDtDate As Date
Dim xName, xFileName As String
Set xShell = CreateObject("Shell.Application")
Set xFolder = xShell.BrowseForFolder(0, "Select a folder:", 0, strStartingFolder)
If Not TypeName(xFolder) = "Nothing" Then
Set xFolderItem = xFolder.self
xFileName = xFolderItem.Path & "\"
xFileName = ""
For Each xObjItem In Outlook.ActiveExplorer.Selection
If xObjItem.Class = olMail Then
Set xMail = xObjItem
xName = xMail.Subject
xDtDate = xMail.ReceivedTime
xName = Format(xDtDate, "yyyymmdd", vbUseSystemDayOfWeek, _
vbUseSystem) & Format(xDtDate, "-hhnnss", _
vbUseSystemDayOfWeek, vbUseSystem) & "-" & xName & ".msg"
xPath = xFileName + xName
xMail.SaveAs xPath, olMSG
Diane Poremsky Save Selected Email Message as .msg File Using Outlook 11
M Save selected email message as .msg file (with user to choose folder location) Outlook VBA and Custom Forms 14
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 14
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
S automate save the .xlxs file to share Network Using Outlook 1
R VBA | Chosing path to save file Outlook VBA and Custom Forms 1
C Outlook - cannot save subject line changes Using Outlook 2
N editing drafts - won't let me save Using Outlook 12
nathandavies Email Details to Excel & Save as .MSG on one macro - combination of 2 macros Outlook VBA and Custom Forms 3
D Save Sent Item to Using Outlook 0
Diane Poremsky Export (Save) Outlook Contact photos Using Outlook 0
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
E Outlook 2016 and Numerous Prompts to Save Emails Using Outlook 3
Diane Poremsky Save Outlook Email as a PDF Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Diane Poremsky Save Attachments to the Hard Drive Using Outlook 2
