What is best calendar practice for iMac
Horsepower
Outlook 2019 for Mac
Outlook.com (as MS Exchange)
I have new Outlook on whatever you call 365 home these days. The reminders are inconsistent. Perhaps because I am using both the onboard calendar pointed to live and my Outlook calendar pointed to live. I need to be able to set a snooze for a different time length. Sometimes I get a reminder within Outlook and sometimes in the Mac calendar. When the Mac calendar does it, I cannot access the reminder in Outlook. Thank you.
Outlook for Mac 16.47
Big Sur 11.2.3
Is the mac calendar in the on my computer folders?
It would probably be better to use one calendar - in outlook.com account as it will sync to web and other devices.
Horsepower
OK I'll see how that works. Thanks.
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest Using Outlook 0
X Best utility for repairing PST files? Using Outlook 3
S Best method to use Outlook Standalone with iPhone Using Outlook 13
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
KeithJB iCloud calendar sync only works one way! Using Outlook 3
O Unable to make changes to an existing Calendar entry Using Outlook 10
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Using Outlook 0
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Exchange Server Administration 0
T Outlook 2010 Cannot edit Calendar entries in OL 2010. Using Outlook 1
M On behalf of not showing on calendar for boss Using Outlook 1
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
K How to share multiple calendar items Using Outlook 1
P Calendar Day View only shows 1 all day event Using Outlook 0
Hobbes Outlook 365 Calendar spreads into second calendar Using Outlook 3
