Posts in Folder No Longer Group by Conversation Column After Search
PeterH
Long before the "group by conversation" feature appeared in Outlook, I have been using folders with items created by "Post to This Folder". In my case, I create posts to remember programming problems I have solved. I use the conversation column to group my posts. This type of item allows me to "Post" to a certain conversation. My view is set to group by conversation and sort by conversation, then created date. I only view three columns: Subject, Created and Conversation. This works great as it has for a thousand years.
But in the last few versions of Outlook (not sure exactly when it started), there seems to be a bug when I search the folder. The group by and sort by don't change but it will not show the "conversation" column anymore and, therefore, it will not group by conversation like the normal view. It groups by subject instead. In fact, the subject appears again in the conversation column, so that's why it is used for grouping.
Oddly, if I open a folder containing only these posts from an old PST, that still works the way it used to, but even when I match the view settings exactly, it doesn't work in Outlook 2016 or later OST. I've waited patiently for MS to fix this bug or to find a solution on google, but nothing has changed in the most recent versions.
I illustrated the problem with snips in the attached PDF.
I've googled this to death and can't find an answer. It's driving me crazy...
Thx
  • Outlook Conversation Column Missing After Search.pdf
O How to delete posts Using Outlook 1
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
J How to get "new lines" (line breaks) in posts here Using Outlook 11
D Outlook 2010: Conversations view - most recent activity posts to of inbox? Using Outlook 2
F Outlook Re-Downloading RSS Feed Posts Days Later Using Outlook 3
T Why is no one responding to the posts? BCM (Business Contact Manager) 2
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
P Print attachments automatically and move the mail to an existing folder called "Ted" Outlook VBA and Custom Forms 5
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
D How to remove a folder, option grayed out Using Outlook 4
D How To Combine Share Task Folders in just one Folder Using Outlook 0
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 2
B Spam folder not showing in Outlook Using Outlook 5
J Moving Imported folder Using Outlook 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
B Outlook 365 - Folder pane list clears Using Outlook 28
R Folder pane width change Using Outlook 76
