Do I need Exchange Add-In?
davegoodo
Outlook 2016 64 bit
I use Outlook365 to connect to my Gmail mailbox, I don't connect to any other mailboxes. I just use Outlook to manage my mail. I'm trying to increase the speed with which MS Outlook loads up. Would I be OK to uninstall the Exchange Server add-in? And would that make any difference to its startup speed? Are there other Add-ins I could also remove if they aren't suitable to my circumstances - that may increase load speed?
davegoodo
Outlook 2016 64 bit
Don't uninstall it - you can disable it - it processes meeting requests so they will not autoprocess if not loaded. It should not be slowing you down though.
So maybe that is not causing the slowness to load, when I say slowness, from clicking it on the Task Bar to fully open it takes between 40 and 60 seconds. Does that sound slow?
I was grasping at straws as to why it seems so slow to load, maybe it is the size of my pst files? My Archive file is 1.6GB and my current file is 450MB, maybe this is what's causing it?
That is slow. Your pst files are puny. What other addins are installed? Does it load a lot faster in safe mode?
davegoodo
Outlook 2016 64 bit
It's good to know my pst files are relatively tiny, that's encouraging. I'll have a look at Safe mode. I've attached a list of Add-ins. By the way, one of the Add-ins - the VBA for Outlook is listed as inactive, does that mean it is still available? Or would I have to do something to make it active?
Thanks for your help Diane :>)
  • MyCurrent_Addins.txt
davegoodo
Outlook 2016 64 bit
By the way I think the time to load is more like 20 to 30 seconds, (It just seemed longer).
T Need to synch pst calendar with exchange calendar Using Outlook 1
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
Horsepower Need iCloud mail only Using Outlook 1
O Don't need any add-ins at all? Using Outlook 2
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Accidentally merged a calendar with .ics, need to undo! Using Outlook 1
D Need Genuine Office or Outlook 2007 Using Outlook 3
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
N Need a case sensitive rule Outlook VBA and Custom Forms 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
mikecox Desperat; need hands on support Using Outlook 1
Glyn Do I Need Outlook.com Using Outlook 1
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
Stig Arvidsson Need a Script for handling moved mail from inbox Using Outlook 3
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
