Archiving and Likely Modified Date Problem
For Outlook 2007...
I seem to have an issue where the modified date on old emails is fairly recent (probably due to a PST repair) and Archiving is not working i with an earlier date. For example: modified = 4/9/21 and archive date = 5/30/18.
I have already modified the registry to add
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Preferences
DWORD Value: ArchiveIgnoreLastModifiedTime
Value data: 1
and then restarted outlook and then restarted the computer.
Still, archiving is not working on the older emails.
I'd appreciate any suggestions anyone has for this! Thanks!
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
P Manual Archiving 2016 Using Outlook 7
L Calendar archiving policy Exchange Server Administration 1
R Archiving into 1 archiving folder only Using Outlook 4
CWM030 Archiving ON the imap server Using Outlook 3
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
G Outlook 2016 Archiving Outlook VBA and Custom Forms 1
Diane Poremsky Archiving Tools for Exchange Server Using Outlook 4
J Search and In-Place Archiving Using Outlook 0
M Archiving by year Using Outlook 1
Fozzie Bear Wishlist A built in Archiving system that allowed storage of messages on a normal file server Outlook Wishlist 1
J Opening/Archiving/Import/Export PST files Using Outlook 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
J Joint mail folders over network and archiving Using Outlook 1
gemini9189 Archiving Emails Into Folders Using Outlook 1
V Archiving Sent Items Using Outlook 1
O Calander archiving problems Using Outlook 4
B Archiving of emails doesn't work anymore Using Outlook 3
Z Outlook and gmail, cloud storage and archiving Using Outlook 2
L Save vs Archiving Using Outlook 0
J archiving deleted e-mails on Microsoft Exchange Exchange Server Administration 7
Fozzie Bear Archiving Emails Using Outlook 2
S Previously flagged messages not archiving Using Outlook 3
V Archiving & IMAP Using Outlook 4
B archiving outlook 2010 Using Outlook 6
H Archiving problem in OL 2003 Using Outlook 5
D Outlook Archiving sent emails which have been moved to inbox folders Using Outlook 1
B Outlook Calendar Archiving Using Outlook 1
N Archiving folders outside of Outlook to reduce PST file size Using Outlook 2
D Outlook 2003 Archiving Outlook VBA and Custom Forms 2
M Archiving Outlook Wishlist 0
J how do I accomplish offline archiving of email? Outlook VBA and Custom Forms 1
U "archive.pst cannot be opened" when archiving Using Outlook 4
e_a_g_l_e_p_i I searched high and low for this answer in its most likely know but I thought I would be sure Using Outlook 24
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
P Updating Last Modified Date on ThisOutlookSession Macro Outlook VBA and Custom Forms 1
P Item cannot be saved because it was modified by another user or window Using Outlook 8
C appending 'Date Modified' to autosave script Outlook VBA and Custom Forms 19
K The file c:\...\Outlook1.pst cannot be accessed because another workstation has modified it. Close a Using Outlook 2
T Cannot open this item becasue another workstation has modified it. Using Outlook 4
S Last modified by login Outlook VBA and Custom Forms 1
