Tasks - how to display "snoozed" tasks and snooze-times?
ofw62
I've a number of 'repeating' tasks, like: record or do this or that.
When done I set a new reminder date. Sometimes I snooze such tasks, i.e. I might postpone it a day, or one or two weeks.
Have looked thru the available fields, but I believe there is no such thing as 'Snooze' or 'Postpone' column ?
Could very well be that I am overlooking something though.
This will create a new email message with a list of snoozed reminders.
Sub SnoozedReminders()
  Dim oReminder As Reminder
  Dim oReminders  As Outlook.Reminders
  Dim RemItems As String
Set oReminders = Outlook.Reminders
  For Each oReminder In oReminders
  If (oReminder.OriginalReminderDate <> oReminder.NextReminderDate) Then
   RemItems = RemItems & oReminder.Caption & vbCrLf & "Original Reminder time: " & oReminder.OriginalReminderDate & vbCrLf & "Snoozed to: " & oReminder.NextReminderDate & vbCrLf & vbCrLf
  Next oReminder
Set oMail = Application.CreateItem(olMailItem)
  oMail.Subject = "Generated on " & Now
  oMail.Body = RemItems
  oMail.Display
ofw62
Thank you so much. Indeed, the macro runs nice.
One would expect a field to be available given the big number of fields available.
Anyway, many thanks again!
Best regards
DaveAndrews
Outlook 365 64 bit
  Next oReminder
  oMail.Display
I am weak at VBA/Macros/Coding but when I run your code I get an error Run time error ...Method Caption of object.... and debugging does not help other than to highlight the line starting RemItems.............................
Can you help or should I seek out the macro forum people ?
Thanks if you can.
Hmmm. It's working correctly here. If you remove 'oReminder.Caption &' from that line and run it, what happens?
DaveAndrews
Outlook 365 64 bit
Hi Diane. Thank you. This works to the extent that the original and snoozed data displays but not anything else by which to identify the "item "??? presumably what's missing is the caption?
O Display more months in 'Tasks' Using Outlook 3
copperberry How to display incomplete tasks due on or before 7 days from now Using Outlook 0
V How to programmatically set "Display reminders and tasks frm pstfolder Outlook VBA and Custom Forms 1
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 5
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 3
K Outlook tasks formatting Using Outlook 4
P Searching tasks that are archived Using Outlook 4
B All imported tasks appear in to-do list Using Outlook 3
T Extract Data From Outlook Tasks Using Outlook 0
I To-do bar (tasks) Using Outlook 1
O Tasks - Is there a postponed date column? Using Outlook 7
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
F some tasks are disappearing Using Outlook 4
F How to show assigned tasks under certain mailbox? Using Outlook 4
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
M tasks in todo list appearing twice Using Outlook 3
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
F Finding Meetings/Tasks in a date range Using Outlook 1
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
F Search folder for tasks in all task folders Using Outlook 1
B Creating an email with the list of tasks Outlook VBA and Custom Forms 0
copperberry How to view all tasks across task folders Using Outlook 3
J Tasks - the missing link... for me at least. Using Outlook 4
Z Tasks from some users show up as emails Using Outlook 4
S Editing Tasks in Outlook 2016 Using Outlook 6
A Outlook incompleted tasks has strike through Using Outlook 3
P Outlook search is not working at all for Calendar & Tasks Using Outlook 7
P Can't search Archive'd Tasks Using Outlook 0
J outlook tasks on a phone Using Outlook 3
F Send multiple batch tasks to single person Using Outlook 3
