Prevent Outlook 2016 from using DASL filter
phrab
Outlook 2016 64 bit
I have Outlook 2016 on Win10 & Outlook 2003 on WinXP. I copy Outlook.pst back & forth. Usually there's no problem. In Calendar view on WinXP, I have TaskPad set to show tasks that have the due date today. I also have, I think it's called To Do list or Peek, shown in Calendar view in Outlook 2016.
There are times when I copy from outlook.pst from 2016 to 2003 where the TaskPad doesn't show today's tasks because the filter is switched to dasl. I can change it back by going into Customize..., unchecking the dasl filter & using the Advanced tab to recreate the filter.
Is there a way to prevent Outlook 2016 from using the dasl filter?
If not, is there a way to have a macro in Outlook 2003 that will change the filter to today's tasks?
Thank you in advance.
phrab
Outlook 2016 64 bit
I suppose if I had the code that would always use today's tasks in the TaskPad, that would work too.
P.S. Is there a way to edit a post after it's posted?
You should have like 10 or 15 min, then no.
its done with views... so and as far as I know, the taskpad is not programmable.
If you create the view in 2003 and move the pst back, does it reset the DASL?
phrab
Outlook 2016 64 bit
Strange. I couldn't find an option to edit. (Now I see it. I must have waited too long before.) :oops:
Yes, it sets it back to Customize... >Filter > Advanced > All tasks > Due Date > Today . I was just hoping for an easier way because sometimes copying from 2016 to 2003 doesn't change the view & sometimes it does. I don't know if there's an SQL code that will set the view to show today's tasks in the TaskPad, but I guess not.
Thank you!!
You have the same view options for all of task windows - but the task pads can only have 1 view. I thought 2003 had a SQL option... will need to see if I can find a VM with 2003 installed and check.
Is is pssoble to lock views - but I don't know if that will work for the taskpad or which view needs locked.
oj43085 Prevent Outlook from blocking image from a single source Using Outlook 4
I How to prevent exchange email account from sending emails in Outlook Using Outlook 4
D Prevent Outlook from resolving incomplete contact when clicking send Using Outlook 2
K How to prevent that Outlook is sending before my add-in is finished? Outlook VBA and Custom Forms 5
C Prevent Outlook from sending an email with a blank Subject Line Outlook VBA and Custom Forms 3
O How to prevent CC from showing when creating a new mail? Using Outlook 1
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Multiple mailboxes, 1 certificate. How to prevent message "Invalid Certificate" Using Outlook 0
S How to prevent addins Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery Using Outlook 0
evdbogaard How to prevent extra line feeds in replies Using Outlook 3
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
B Item_Write = False don't prevent custom form from closing Using Outlook 1
N Allow Another User to Send on Behalf of But Prevent Access to Inbox Using Outlook 4
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
M Links prevent sending email Using Outlook 3
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
Z Prevent Changes to Custom Form Outlook VBA and Custom Forms 1
M Outlook 365 refuses to send email Using Outlook 0
P How can I stop Outlook 365 duplicating the posts? Using Outlook 0
A force outlook to default to MY calendar Using Outlook 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
A Outlook Reminders not populating for certain events Using Outlook 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
