Icons (arrows) not showing on emails forwarded or replied to
Ched
Outlook 365 64 bit
Hi I have seen this query posted many times - years apart and can see no clear answer that works. Been hit and miss over the last few months but when I forward an email it will mark it as read but does not let me know if I have replied to or forwarded said email. This means having to go into sent email to see what happened. Today I can see icons against a couple of the emails I replied to yesterday (not all) and no icons against any emails I have dealt with today :mad:
This is an office PC and cant remember having any issues at all until we upgraded (not by choice) to 365 and had to pay dearly for the privilege. Grateful for any help.
It's an IMAP issue - Outlook is sometimes bad at displaying the icon - you may see it immediately or always on the computer where you sent the reply from but not on other computers that are syncing. They fix it, then it breaks again.
Ched
Outlook 365 64 bit
Thank you for quick reply and sorry to have asked the same question as many before me. Just thought they may have got their act together and finally fixed it for good. Thanks for getting back to me Diane.
Ched
Outlook 365 64 bit
Update on problem which you may find interesting! This morning I managed to contact Microsoft support and they provided the following guidance -
Thank you for contacting Microsoft In-App support. My name is Krishna and will be glad to assist you with this issue.
As per your issue description, I see that icons are not appearing by emails that I have either forwarded on or replied to in your Outlook.
Let us run Office Quick repair,
- Close Outlook.
- Press Windows key and R key simultaneously on the keyboard.
- Type appwiz.cpl and hit Enter.
- Select Microsoft Office application or Office 365 from the list > click on Change > choose Quick Repair.
- Wait until Quick repair completes. Once done, check the behavior.
Please do keep me posted. Thank you!
So far this is working for me - I have icons back!
Hope this helps other sufferers (and hope this fix lasts!)
Yeah, repair usually fixes it for a while.... fortunately, quick repair is fast and easy.
deejerydoo
Outlook 365 64 bit
Sadly this is not a problem related to just IMAP connected clients. I consistently see this issue when moving between Outlook for iOS, macOS and Windows. I'm a MS partner and see this all the time, across all my clients as well, accessing Outlook from different platforms. Microsoft have been aware of this issue (confirmed through support cases) for a number of years and have always obfuscated the issue and written it off as an IMAP failure combined with "we don't support IMAP as a core function". However, as I have said, this is definitely not just an IMAP failure but a product-wide failure.
Microsoft will perceive this as a low value issue and will only look to address it when/if their customers start to make it a higher value issue. This is how software product development works these days.
Nothing is fixed simply because it is broken. If something is broken, it will only get fixed if it is creating enough of a liability to the product, whether that be reputationally or legally or otherwise. If it isn't perceived as enough of a liability and remains broken for long enough it'll make the list for retirement from the product, all together.
footballer127
Outlook 365 64 bit
Outlook.com (as MS Exchange)
Do you think this problem can occur on outlook.com main web page?
You shouldn't see it with Outlook.com on the web or Exchange accounts, only IMAP accounts. The icon indicator is not picked up when the IMAP accounts sync with the server.
T why are the calendar icons different for different accounts Using Outlook 2
W Account icons Outlook for Android Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
O How to display folder icons? Using Outlook 2
P Skype contact icons have disappeared at the bottom of email and meeting objects Using Outlook 2
C What happen to the little grey icons at the bottom Using Outlook 5
C how to remove icons on right hand side outlook 2013 Using Outlook 2
M resetting contact file icons in Outlook 2013 Using Outlook 1
C Form icons are missing in Outlook 2013 supergrid Using Outlook 5
M What Do The Different Calendar Icons Mean? Using Outlook 1
T Word 2007 add-in ribbon icons greyed out Outlook VBA and Custom Forms 1
S problem with transparency in custom icons. Outlook VBA and Custom Forms 3
F Resizing arrows unavailable only in Outlook Using Outlook 3
P email arrows - respond and forward Using Outlook 1
H Arrows blue and purple not always visible Using Outlook 0
J Outlook 365 Emails showing as links and text only Using Outlook 4
M On behalf of not showing on calendar for boss Using Outlook 1
B Spam folder not showing in Outlook Using Outlook 5
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
O How to prevent CC from showing when creating a new mail? Using Outlook 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
B When sending an email, I am showing 2 of my address's Using Outlook 1
M Sent mail not showing in my sent folder Using Outlook 9
O Reminder due end of August is showing up now Using Outlook 2
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
Z Outlook for G Suite emails showing wrong dates Using Outlook 4
C Outlook 2016 cannot delete, email showing in root Exchange Server Administration 5
V Spam folder not showing in Outlook Using Outlook 4
3 New emails not showing up Using Outlook 5
M attached images not showing in text area Exchange Server Administration 0
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
W Showing more months in the Calendar nav pane Using Outlook 10
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
A Updated custom form not showing with old items Outlook VBA and Custom Forms 2
B Emails from a single gmail address not showing in Outlook 2016 Using Outlook 1
H Outlook Images showing as hyperlinks Using Outlook 3
K Outlook 2013 Recurring Tasks Not Showing Complete Outlook.com Using Outlook.com accounts in Outlook 1
R Tasks showing up in inbox? Using Outlook 15
P Newly created IMAP subfolders not showing up on email clients away from computer. Using Outlook 3
