Changing where data .pst is saved to
e_a_g_l_e_p_i
In Outlook 2010 In account settings if I change the location where Outlook saves all new messages on the email tab, does that also change the location of the .pst in the data tab to the same location I changed it to?
The reason I ask is I use a program called GoodSync to copy my main storage drive ( D drive ) to 2 other drives so I always have 3 exact copies of what is in my main storage drive ( not my C drive )
The reason I need to know this is I want to change the location on the account settings email tab to my main storage drive. This way when I run my GoodSync I will be making a copy of the current .pst file so I always have copies of the most current .pst file.
e_a_g_l_e_p_i
while waiting for a reply I found Diane's tutorial on how to move a .pst and I was able to move it and when I ran my GoodSync and the .pst was copied to the other 2 drives. So I accomplished what i was trying to do.
e_a_g_l_e_p_i
I spoke too soon, it seemed to work when I moved the .pst file and then ran my backup software. when I opened Outlook 2010 again I noticed that the send and receive that I added to the home ribbon wasn't there. so I clicked on the send & receive tab and when I clicked it it said it couldn't access the data file???
So I moved the .pst back to the default location and now when I opened Outlook the Send & receive was back on the home tab and everything is working fine.
I guess I will have to figure out a different way for my backup software to make a copy of the .pst to my other drives.
Move it again... then open the Account settings, select the pop account then Change folder button. Select a folder other than the inbox, preferably in a different data file and click Ok then go back in and change it to he inbox it should be in.
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 3
S Changing Message Class Outlook VBA and Custom Forms 4
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
M CHANGING ACCOUNT NAME Using Outlook 0
J Changing margins in received email display Using Outlook 3
B Automatic picture download and changing email addresses Using Outlook 3
L changing view settings based on message body Using Outlook 1
M How to automatically refresh an appointment windows after changing the MessageClass property ? Outlook VBA and Custom Forms 4
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
