Outlook 2019 Randomly Disconnecting from Gmail Servers
Korishan
Outlook 2019 64-bit
I have 2 gmail accounts connected to my Outlook 2019. Everything worked fine up to about 2-3 weeks ago. Randomly Outlook will stop being able to connect to my gmail accounts. I can restart Outlook without success. The ONLY fix is to reboot my computer and then Outlook will connect just fine. And then, after unknown amount of time, it will randomly stop connecting again and I have reboot, AGAIN, to fix the issue.
Creating a new PST/Profile does NOT fix the issue.
Deleting and re-adding the accounts does NOT fix the issue.
Doing a Repair on Office does NOT fix the issue.
Loading in Safe Mode does NOT fix the issue.
I am up to date on all updates for Outlook, which I even double checked again today to make sure it was updated (went to About and Check Updates). Windows Update also does no show any updates for Office 2019.
What is going on here and how to get this fixed?! Having to reboot my computer just to check my email is not very productive.
Korishan
Outlook 2019 64-bit
well, apparently it's not *Outlook* directly. Must be some service it uses or something. I rebooted my system and didn't reload Outlook immediately. Been about an hour. I loaded it up, and it won't connect to the gmail server.
Korishan
Outlook 2019 64-bit
The only error that shows up is this:
Task 'Synchronizing subscribed folders for ***@gmail.com.' reported error (0x800CCC0E) : 'Outlook cannot synchronize subscribed folders for ***gmail.com. Error: Cannot connect to the server. If you continue to receive this message, contact your server administrator or Internet service provider (ISP).'
Which isn't very helpful, considering it works right after a reboot, but waiting awhile it stops.
Korishan
Outlook 2019 64-bit
Randomly, for some unknown reason, it started working just fine. I have no idea what happened.
Korishan
Outlook 2019 64-bit
oh wonderful! Now it's not checking/sending my xfinity/comcast account!!! !?!?!!??
Korishan
Outlook 2019 64-bit
Oh this is freakin frustrating. Just did a "Security Update" yesterday, and now it stops checking the gmail accounts again!!
I reboot, load up Outlook, and it works for a few times. Then stops checking the gmail accounts. WTH!?!?!?
Korishan
Outlook 2019 64-bit
Wanting to do an update to this. I'm beginning to think that it is "not" Outlook or MS in this particular case.
On my mobile phone I use a client called Edison Email. Over the past couple days I got 'notifications' of new email in my gmail account. But when I open the application up to view them within the app, there is no email listed. Today is 9:50pm Thursday. The last email I have listed is from 12:52pm Tuesday. Even doing a forced refresh won't update the mail listings.
However, if I go to mail.google.com there's all the emails from the past couple days shown clearly.
So apparently there is an issue with Google Email Services. :mad:
Have you logged into gmail.com to look for security messages?
If you are not using 2-step authentication, Google will disable 'allow less secure apps' and often post a message asking if the sign in attempt was you.
Otherwise, yeah, it could be a general google issue. But log into Gmail to verify it's not google blocking you.
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
H Outlook 2019 intermittent search results Using Outlook 0
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
witzker Outlook 2019 is cutting Picture Extension *.pn_ Using Outlook 3
A Outlook (and Office) 2019 Logging Using Outlook 2
witzker Open Contact missing in Outlook 2019 Using Outlook 2
C All Gmails don't show in Outlook 2019 Using Outlook 2
J How do I disable advertising in Outlook 2019? Using Outlook 15
R Outlook 2019 Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
B Seeking help with Outlook rule Using Outlook 0
A Outlook Reminders not populating for certain events Using Outlook 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
hstein POP3 latest Outlook Using Outlook 0
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
F Moving Outlook to new PC Using Outlook 0
Ken Pascoe Outlook Categories Quick List Using Outlook 0
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 3
