Create ordinal numbers for birthday
Post number 2 has been selected as the best answer.
gaib
Outlook 2016 64 bit
I'm using the age script from here, but have the question, how can I get the ordinal number for the birthdate?
You would need to get the number - then add the ordinal using select case.
Get the last value in the age - and add the ordinal:
Select Case CLng(Right(age, 1))
Case 1
OrdinalAge = age & "st"
Case 2
OrdinalAge = age & "nd"
Case 3
OrdinalAge = age & "rd"
Case Else
OrdinalAge = age & "th"
Then, to account for the 3 that are different... check if 11, 12, or 13:
Select Case CLng(Right(age, 2))
Case 11, 12, 13
bday = bday + 0.25 ' sets it for 6 am the day of the birthday
age = DateDiff("yyyy", oContact.Birthday, bday)
    Case 1
    Case 2
    Case 3
    Case Else
    Case 11, 12, 13
Debug.Print age, OrdinalAge
Dim objMsg As MailItem
  objMsg.To = oContact.Email1Address
  objMsg.Subject = "Happy " & OrdinalAge & " Birthday"
  objMsg.Body = "Hope your day is a happy one! May you enjoy the next " & age & " years as much as the last " & age & "!"
  objMsg.DeferredDeliveryTime = bday
  'displays the message form so you can enter more text
  objMsg.Display
Diane Poremsky Create a Task when a Message is Flagged Using Outlook 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
Diane Poremsky Automatically create a task when sending a message Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
