All fonts in Outlook emails display with exaggerated character spacing
moncur83
Outlook 365 32 bit
Here is a problem that has me stumped...
The individual characters in all of my Outlook emails are being displayed with greatly exaggerated character spacing.
This is affecting all emails - both emails I compose, and emails I have received.
It doesn't make any difference which font is used as the default font for composing emails, or which font the sender used when composing the emails that I have received from them.
I've attached an example screenshot of the exaggerated character spacing.
The problem is only with the way Outlook is displaying the emails on my PC, as opposed to the actual formatting of the emails. If I forward the emails to another PC, they display with normal character spacing between the letters. If I compose an email and check the character spacing options in the Fonts section, the character spacing is normal. The problem is not with the actual formatting, but the way Outlook is displaying/rendering the text of the emails.
The problem only affects Outlook - character spacing in Word displays correctly.
I haven't noticed the issue appearing anywhere else on the PC other than Outlook.
I have tried repairing Outlook and adjusting the settings in Outlook options -> Mail -> Message Format.
I've tried tuning off all Outlook add-ons, and deleting/recreating both Normal.dotm and NormalEmail.dotm templates in C:\Users\{USER}\AppData\Roaming\Microsoft\Templates
Nothing has made any difference.
Any suggestions would be greatly appreciated.
tempman
Outlook 2016 64 bit
Hi, I had the same problem.
When viewing an email check the top of Outlook for a tab called 'Immersive Reader'. Here, there is a button called 'Text Spacing' which you can toggle on or off. My guess is that it's turned on by accident.
ibeldesouki
Outlook 2019 64-bit
pls use Open Immersive Reader for Outlook to adjust the spacing issue ,
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
L Ever notice that the fonts in Outlook seem to be depend on the build? Using Outlook 1
N Outlook 2010 prints in small fonts Using Outlook 1
P Outlook Fonts not Sticking Using Outlook 10
D Point Size for Fonts in Custom Font Style (Outlook 2013) Using Outlook 0
B Fonts cut off when composing new email on outlook 2007 Using Outlook 1
N Column view fonts Using Outlook 4
O Non-standard fonts - are they embedded? Using Outlook 2
T Incoming Mail Changes Fonts Using Outlook 0
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
Commodore What's the deal with fonts Using Outlook 6
E fonts suddenly bigger by 2x Using Outlook 3
F How to change all incoming fonts to black? Using Outlook 3
K Default Fonts Using Outlook 9
T Text fonts changing when exchange syncs Using Outlook 0
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
