print attachment straight away; working script edit not working
Gazmoz17
Outlook 2016 64 bit
I have used your below script and its a great time saver. Ive adapted it and applied it to one script rule, changing the sDirectory to a diff location.
Tried to duplicate this script calling it a new sub name in new module and changing the sDirectory...then applying to a new script rule and it's not working for some reason, even though exacty the same script other than changes mentioned?
Working Script:
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias _
  "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
  ByVal lpFile As String, ByVal lpParameters As String, _
  ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
 Sub PrintAttachments(oMail As Outlook.MailItem)
  Dim colAtts As Outlook.Attachments
  Dim oAtt As Outlook.Attachment
  Dim sFile As String
  Dim sDirectory As String
  Dim sFileType As String
  sDirectory = "G:\My Drive\Outlook attachments\End of Day\Sage\"
  Set colAtts = oMail.Attachments
  If colAtts.Count Then
    For Each oAtt In colAtts
' This code looks at the last 4 characters in a filename
      sFileType = LCase$(Right$(oAtt.FileName, 4))
      Select Case sFileType
' Add additional file types below
      Case ".pdf", ".doc", "docx"
        sFile = sDirectory & oAtt.FileName
        oAtt.SaveAsFile sFile
        ShellExecute 0, "print", sFile, vbNullString, vbNullString, 0
Not working:
  Sub PrintAttachmentsCash(oMail As Outlook.MailItem)
  Dim sFile As String
  sDirectory = "G:\My Drive\Outlook attachments\Cash Sheet\"
1st script saves and prints summary of card takings for the day.
2nd script I wish to do the same but for cash takings.
I think Ive read you literature where is says make the folder move within the vba script rule....but I dont know how to add this. Maybe this is causing the complication. However, the working script rule mirror the above rule steps in outlook (e.g move to folder first/separate from script rule).
Many Thanks
Gareth
R Print email message and attachment in order Outlook VBA and Custom Forms 2
L Outlook 2010 Quick Print Attachment, nothing happend Using Outlook 0
S Cannot print Contacts Using Outlook 7
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
M Batch print without appended trail of repeated e Using Outlook 2
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
A Day view - print appointment details Using Outlook 1
I print calendar without subject and details Using Outlook 1
oliv- property "is printed" or catching print events Outlook VBA and Custom Forms 2
Diane Poremsky Print a list of your Outlook folders Using Outlook 0
Diane Poremsky Combine and Print Multiple Outlook Calendars Using Outlook 0
B Print list of previously sent recipients Using Outlook 1
A Print first page of a new email Outlook VBA and Custom Forms 7
Diane Poremsky Print Monthly or Work Week Calendars Using Outlook 0
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
S Macro to print & move selected emails? Using Outlook 3
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
G Calendar monthly view - Print just 3 weeks Using Outlook 5
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
M Print Attachments from another mailbox (not default) Outlook VBA and Custom Forms 2
C automatically print attachments Using Outlook 4
J Automatically Print PDF When They Are Received Using Outlook 4
M button to send and print emails Using Outlook 26
S How to print ONLY first line of appointments in month view? Using Outlook 1
M print free/busy schedule of an user Using Outlook 2
O For Outlook 2007 - VBA to print attachments Using Outlook 1
W Cannot print Outlook 2007 emails Using Outlook 2
R problem with incomming e-mail I am unable to print full e-mail letter Using Outlook 1
M Custom print contacts Using Outlook 2
E Can't print from Outlook on wifi network Using Outlook 0
E can't print some retail discount coupons Using Outlook 7
J calendar print setup in outlook 2010 Using Outlook 1
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
D Use Outlook 2003 embedded imaged cannot print from the mail preview list Using Outlook 4
J Print next 7 days view of calendar (2010) Using Outlook 3
C Print all emails in a single folder with sent items Using Outlook 2
