SCANPST errors Outlook PST repair?
John2222
Outlook 2019 64-bit
Microsoft 365 Outlook (Win 95 home). I am getting repeated errors with SCANPST.EXE. What is the approach/recommendation to repairing Outlook PST (about 80 MB) file? I've tried demo versions of several programs. They all seem to create a new PST file.
After running SCANPST multiple times I still get the errors (see log attached). Any good PST scan/repair software recommendations? Or just ignore the SCANPST error messages? (Outlook seems to run ok otherwise).
Thanks for any suggestions.
  • OUTLOOKlog.txt
You will always have errors in the pst - it's a database and they are always "dirty". Most errors will be minor and Outlook will fix them automatically.
We recommend running scanpst 3 times in a row - the last pass will find errors but probably not enough to fix. The only time you really need a 3rd party utility is if the pst won't open and scanpst can't fix it.
P errors appear every time I run SCANPST Using Outlook 3
A ScanPST finding errors but no Repair button Using Outlook 2
C scanpst.exe doesn't repair .pst file Using Outlook 1
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
C scanpst.exe will not open Using Outlook 0
makinmyway ScanPST.exe Missing Repair Button Using Outlook 15
G Error when running scanpst.exe Using Outlook 1
Jennifer Murphy ScanPST results discarded? Using Outlook 10
R ScanPST finished, but no repaired folders appeared? Using Outlook 1
S Using Scanpst too often? Using Outlook 2
V How to do a scanpst in thin clients??? Using Outlook 5
W scanpst gets freezed Using Outlook 2
H ran scanpst.exe and that fixed most, but cannot access personal folders Using Outlook 1
S CSCANPST To Automate Running SCANPST.EXE Using Outlook 1
N Inbox repair tool - scanpst.exe. That file is missing from my computer. Using Outlook 2
B Outlook fails - error says execute scanpst.exe but can't find it Using Outlook 8
Y IMAP errors with Outlook 2016 Using Outlook 2
M Charter ISP Claims Outlook Generating STMP Errors of Too Many Recipients Using Outlook 1
Diane Poremsky Common Outlook Outgoing Server (SMTP) Errors Using Outlook 0
M attachments & time-out errors Using Outlook 4
L Issues with Outlook - errors detected in file Using Outlook 1
P 2013 AOL IMAP Sync Errors Using Outlook 5
E Multiple, intermittent Outlook 2010 errors Using Outlook 12
icacream errors have been detected... outlook.pst Using Outlook 10
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
M The set of folders cannot be opened. Errors have been detected in the file. Using Outlook 11
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
V What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail Using Outlook.com accounts in Outlook 3
M Outllook 2000 - 2 Errors - The Information Service / The Messaging Interface Using Outlook 7
P IMAP errors with AOL during sync Outlook VBA and Custom Forms 3
B Import to Access errors out Outlook VBA and Custom Forms 20
T field mapping errors during import BCM (Business Contact Manager) 1
D BCM 2007 errors BCM (Business Contact Manager) 5
L Out of memory errors and Auto-linking hangs BCM (Business Contact Manager) 2
R Errors while adding new item to main menu Outlook VBA and Custom Forms 4
C HANDLING ERRORS USING FIND Outlook VBA and Custom Forms 3
L Restoring Outlook from backup pst file Using Outlook 1
