Seeking PDF Recommendation for Outlook that retains links
MOutlook
Hi all,
Seeking recommendations for a PDF utility (preferably free), that will work with the Outlook email client and preserve hyperlinks contained in the body of the email.
I am using an older version of the Adobe product, but the produced PDF does not have working hyperlinks. (I have also tried CutePDF).
The procedure I follow is 1. Open the email so it is viewable on screen 2. Go file > print > select the PDF printer 3. Save with file name of my choice.
Thanks for any assistance.
It should be an option in the pdf software. Oh, but not when you print - you need to save as pdf.
The Acrobat addin should be able to save as pdf. I have not tested other pdf addins - but you definitely want to save as pdf, not print.
MOutlook
I am using Outlook 2016, and when I go 'save as' there is no PDF option. (I only have .txt, .mft, .osg, .html, .mht).
You need to have a pdf app installed that includes an outlook addin.
Which version of Acrobat do you have? Is there an Acrobat addin in Outlook's File > Options > addins?
MOutlook
Acrobat is quite old - CS6.
Went to addins for Outlook. Under Inactive Application Add-ins there is one called 'Acrobat PDFMaker Office COM Addin'.
I have tried making it active - it appears to - but when I go back to have a look, it is still showing under Inactive Application Add-ins.
Vince
Outlook 2021 64 bit
Printing an email with "Microsoft Print to PDF" seems to preserve hyperlinks for me here. I think it just comes with Windows-10.
MOutlook
I just tried "Microsoft Print to PDF". For me, it will create hyperlinks for any email addresses found. But for existing hyperlinks in the original email (say a shortened link that takes you to a particular website), does not create a hyperlink.
I had a look at the settings for the "Microsoft Print to PDF" virtual printer and there are no options to do this (no options to do anything really, it appears to be just a basic PDF creator). Also, does not enable a 'save as' option (as Diane mentioned above).
Keep the suggestions coming......
Vince
Outlook 2021 64 bit
Worked for me, with an HTML-based newsletter from my Inbox, and yes ... with actual URL links to a website.
However, further testing revealed that when printing the Newegg sales-ad, it did not seem to re-create links embedded in images. So, it does seem to depended on the actual coding of the HTML emails.
Adobe Acrobat is good. I have also used Nuance Power-PDF and Foxit-PDF on various computers over the years. Good luck in your searches. Maybe let us know which one you found in the end.
E Newbie, desperately seeking help Using Outlook 2
S Dead computer-- desperately seeking address book Using Outlook 1
Commodore PDF attachments started to open in Edge Using Outlook 0
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
X Outlook automation pull from PDF Using Outlook 5
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky Save Outlook Email as a PDF Using Outlook 0
B Auto open PDF Outlook VBA and Custom Forms 0
P Printing PDF attachments of Outlook message attachments Outlook VBA and Custom Forms 2
R how to open a pdf file with a known password Outlook VBA and Custom Forms 1
V Emails, pdf.s ocr - oh my Using Outlook 1
E PDF Import Using Outlook 1
D Save pst and attachments as a PDF File Outlook VBA and Custom Forms 3
J Auto print PDF attachments as they arrive with certain words in subject Outlook VBA and Custom Forms 3
J Automatically Print PDF When They Are Received Using Outlook 4
J How to open PDF attachement upon arrivel new mail Using Outlook 20
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
L Inserting a PPT/PDF into the message body Using Outlook 1
B Outlook 2007 corrupting PDF attachments Using Outlook 4
J Opening a web URL that points to PDF file... Outlook VBA and Custom Forms 7
G pdf format in access 2007 Outlook VBA and Custom Forms 1
W Displaying custom properties of a PDF DocumentItem Outlook VBA and Custom Forms 3
