Use OST file location for fresh installation?
Outlook 2016 64 bit
My *.OST files are located in F:\Libraries\Documents\Office\Outlook, which is where I want it to be. I've been meaning to do a fresh clean Windows installation for awhile now, but the possibility of losing the custom path and OST files prevented me from doing so.
Is it possible when installing Outlook 365, to specify the existing files and location? If so, what would the steps I need to take be?
Before creating the profile, you can set a registry key to use the custom path. Actually, if you are just refreshing the computer, you can export the outlook profile - that will bring the accounts and use the ost files. run the reg file before you open Outlook for the first time. This will reuse the ost file. If you create a new profile, it will create new ost files.
Move the ost file:
The profile is at HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Outlook\Profiles
You could export the entire outlook or office keys - then after reinstalling office, but before running the apps, run the exported registry.
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
S Moving .OST file location unsuccessful! Using Outlook 6
H Can't change the location of the Data File (.ost) in Outlook 2013 Using Outlook 2
HarvMan Exporting IMAP OST file to PST Using Outlook 5
BretAB Connected vs Connected Headers vs OST file. Exchange Server Administration 2
BretAB Connected vs Connected Headers vs OST file. Using Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
R ost file import Using Outlook 2
J How to Fix “Encounter a large number of conflict items in Exchange OST file” Using Outlook 2
O Moving .ost file Using Outlook 12
C Converting OST to PST File Using Outlook 3
B How to recover deleted MS Outlook OST file? Using Outlook 4
T OST vs PST file size Using Outlook 2
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) Using Outlook 0
S How to do I convert OST file to PST? Exchange Server Administration 3
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
Diane Poremsky Moving an Outlook offline data file (*.ost) Using Outlook 3
V Import from Outlook 2013 ost file? Using Outlook 2
Tony H. I want my OST file permanently deleted Using Outlook.com accounts in Outlook 5
D Outlook 2013 .ost File Size Exchange Server Administration 2
M How do I Repair OST File from corruption and Recover OST data? Using Outlook 3
O Previous OST file items are inaccessible Using Outlook 1
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R How to recover old hotmail messages from an .ost file Using Outlook.com accounts in Outlook 3
D Unable to open hotmail, error hotmail.ost is not an offline folder file Using Outlook 3
K Extracting Calendar information from a OST file? Exchange Server Administration 5
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
L Restoring Outlook from backup of OST Using Outlook 5
V Carbonite not backing up .ost files Using Outlook 7
E How to transform .OST in .PST ? Using Outlook 1
C OST email backup Exchange Server Administration 1
myPalabok not all emails are in OST Using Outlook 2
