Out of memory when click History button
Roberto Fernandes
Hello all
I´ve installed BCM in Outlook, in a coreDuo machine with 4GB RAM.
EVERYTIME I enter on a contact details and click in the button HISTORY
(to see past e-mails, tasks and appointments - A feature that I need)
I got the followeing error:
"Out of memory or system resources. Close some windows or programs and
try again".
Don´t matter if outlook is the only program open... and has LOT of RAM
available to use... and the C: Drive has more than 60GB free
That error is just driving me crazy, because happen only in history
and there is no chance to see the past interactions with my contacts.
Thanks for any help, and excuse the terrible English :)
Roberto Fernandes
nobody can help??
On 24 mar, 10:36, Roberto Fernandes <fatordigi...@gmail.com> wrote:
> Hello all
> try again".
P
Pulsewan
It seems many of us are in the same boat on the memory issue. I have 2gb of
memory free, plenty of hard rive space, a fast processor and recent software
load. Did you load Office Service Pack 2 ?
"Roberto Fernandes" wrote:
> nobody can help??
> > Hello all
> > try again".
G "Cannot load GUI library into memory" Outlook VBA and Custom Forms 3
A active inspector in memory Outlook VBA and Custom Forms 1
M Not enough free memory BCM (Business Contact Manager) 11
C Business Contact Manager and Outlook 2007 "not enough free memory BCM (Business Contact Manager) 5
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
R Outlook staying in memory Outlook VBA and Custom Forms 2
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
L Out of memory errors and Auto-linking hangs BCM (Business Contact Manager) 2
Diane Poremsky Using Scanpst in Outlook Click to Run New Slipstick.com Articles 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button New Slipstick.com Articles 0
M Office 365 Click to run BCM (Business Contact Manager) 0
williamlambton Reinstate "Open" button on mail item right-click context menu. Outlook Wishlist 2
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
L Add to Right Click Menu Using Outlook 10
T Is the standalone Outlook 2013 click-to-run or msi? Using Outlook 1
A Uninstall Click and Run Exchange Server Administration 2
B Right click-drag no longer creates hyperlinks Using Outlook 2
A email folders appear empty, at first click Using Outlook 2
P "open" command in right click context menu Outlook Wishlist 4
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
T Click "A" to see all email from people with names starting with A... etc Using Outlook 3
V Can't click on embedded link in Outlook e-mails--error message "not allowed" Using Outlook 6
M right click contact to create an appointment Using Outlook 4
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
F When I click on link in email nothing occurs Using Outlook 7
M Programatically click the Send button. Outlook VBA and Custom Forms 5
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
M auto click hyperlink?! Outlook VBA and Custom Forms 1
M Auto click a hyperlink Outlook VBA and Custom Forms 2
