Program Compatibility Issue - Outlook 2003 BCM
jaygreg
I have three discs for Office 2003 Professional; the first that installs the
suite of programs, a second that installs Outlook 2003 BCM, and a third
labeled Microsoft Office Professional, Enterprise Edition 2003, Service Pack
1. These were originally installed on my Windows XP machine. My new 64 bit
machine runs Vista.
I installed the first disc successfully on the new Vista machine then - not
sure which disc should come next - I chose the Outlook 2003 Business Contact
Manger disc. Windows Installer paused during the process and sent up a
second window entitled "Program Compatibility Assistant". It read:
"This program has known compatibility issues. Check online to see if
solutions are available from the Microsoft website. If solutions are found,
Windows will automatically display a website that lists steps you can take."
It then identified the program involved as Microsoft.NET Framework 1.1 in
"Location: Not Available". It went on to say at the end that "This software
has known incompatibility with IIS on this platform."
The above window was followed by one entitled "Problem Report Solution"
which read: Download updates for Microsoft.NET Framework 1.1. The problem
was caused by a compatibility issue between this version of Windows and this
version of Microsoft.NET Framework 1.1. This program was created by
Microsoft Corporation.
Solution. Go online to the following website to download an update that
solves this problem.
I clicked "Microsoft Corporation" as prompted and got this message in
another "Windows Installer" window which I subsequently closed or it closed
itself:
"The upgrade patch cannot be installed by the Windows Installer service
because the program to be updated may be missing, or the upgrade patch may
update a different version of the program. Verify that the program to be
upgraded exists on your computer and that you have a correct upgrade patch."
Well... it sounds like Framework 1.1 is simply missing or can't be
recognized which leads me to believe it may have something to do with that
SP1 disc; the third disc I never got to. Perhaps I'm wrong. In any event, I
walked away from the machine and plan on retiring for the night (6 hours)
leaving all the windows open on the desktop. I'm concerned that Vista will
attempt to update itself around 3AM but I'm hopeful it has enough artificial
intelligence to realize something 's in progress and it won't gum up the
works.
Can someone please tell me how to back out of these windows (since I'm
technically still in the process of an installation) and then give me some
guidance on how I resolve the issue in order to complete the installation.
DL
Close the windows, you may get a msg that the installation failed and it
should then roll back any installed files.
With the first disk installed, presumably correctly, run WinUpdate, to see
if it gives any Office updates.
Do not install the third Disk - Enterprise -
PS You did uninstall any Office Trial prior to installing Office from cd?
"jaygreg" <jaygreg90@hotmail.com> wrote in message
news:eK8d$wVyJHA.4628@TK2MSFTNGP05.phx.gbl...
> the suite of programs, a second that installs Outlook 2003 BCM, and a third
> Pack 1. These were originally installed on my Windows XP machine. My new 64
> bit machine runs Vista.
> not sure which disc should come next - I chose the Outlook 2003 Business
> Contact Manger disc. Windows Installer paused during the process and sent
> up a second window entitled "Program Compatibility Assistant". It read:
> found, Windows will automatically display a website that lists steps you
> can take." It then identified the program involved as Microsoft.NET
> Framework 1.1 in "Location: Not Available". It went on to say at the end
> that "This software has known incompatibility with IIS on this platform."
> this version of Microsoft.NET Framework 1.1. This program was created by
> closed itself:
> patch."
> I walked away from the machine and plan on retiring for the night (6
> hours) leaving all the windows open on the desktop. I'm concerned that
> Vista will attempt to update itself around 3AM but I'm hopeful it has
> enough artificial intelligence to realize something 's in progress and it
> won't gum up the works.
jaygreg
>>run WinUpdate<<
I was very confused about that as well. Now it's clear to me; my problem
probably stems from that very step. Here's what happened:
After I installed the first disc I was taken to a web site that appeared to
be a catalog of downloads. The dominant product was Office 2007 but there
were others listed on the side including my 2003. Because I saw nothing with
the word "update" - only "download" - I thought this might be (incorrectly
now) another download of what I already put on the machine. (I don't think
clearly beyond 1 AM :)). Anyway... I decided that I should probably just
install the next disc and maybe it would be cleared with its subsequent
update routine. You know the rest. This is obviously where I failed. That
Framework stuff is somewhere on that page I assume.
There was a long list of programs in the middle - which I now think may have
been what I should have been dealing with - that I dismissed because I say
something that appeared to be a mini program with "2006" in its title. At 1
AM my mind said "that's a program later than 2003 so so it can't be
something that belongs to whatever I'm supposed to be finding". So I
dismissed the lot and installed disc 2.
I'll go back to that space and spend more time this morning. Perhaps things
will be clearer. When I pressed that "Update" button at the top of the page
I was taken to, I expected a list that would jump out at me. Instead, I
became confused. I'll try again now and report back.
I appreciate the help, DL.
"DL" <notvalid@spoofaddress.co.uk> wrote in message
news:%23jdrmfWyJHA.5496@TK2MSFTNGP04.phx.gbl...
> >third labeled Microsoft Office Professional, Enterprise Edition 2003,
> >Service Pack 1. These were originally installed on my Windows XP machine.
> >My new 64 bit machine runs Vista.
> > closed itself:
> > may update a different version of the program. Verify that the program to
> > be upgraded exists on your computer and that you have a correct upgrade
> > patch."
> > that SP1 disc; the third disc I never got to. Perhaps I'm wrong. In any
> > event, I walked away from the machine and plan on retiring for the night
> > (6 hours) leaving all the windows open on the desktop. I'm concerned that
> > some guidance on how I resolve the issue in order to complete the
> > installation.
jaygreg
Further complications. The first program I installed on the new machine was
the latest version Firefox. That's what I used at the start of the
installation of MS Office 2003 Professional. When I hit the point where it
was recommended I get updates, I brought up Internet Explorer and closed
Firefox. However, there are TWO versions of IE on my menu. Having a 64 bit
machine, I logically selected that version; the 2nd one listed. I read this
morning that not even MS recognizes that version on some of their sites.
This might explain why I got such little response when I clicked the
"Updates" button at the top of the page that was supposed to lead me to
updates for 2003 Office.
This morning I select that 1st version (the 32 bit version) of IE and went
to the Updates page again. A message appeared at the top telling me
something wanted to be run so I clicked it and got this message in the
process:
"This website wants to run "Authzax.dll from Microsoft Corporation." I
clicked on "Run ActiveX Control" and got an "Internet Explorer - Security
Warning" window that asked if I wanted to run "Authzax.dll". At the bottom
is an orange caution emblem (shield with exclamation mark) with this message
to the right:
This ActiveX control was previously added to your computer when you
installed another program, or when Windows was installed. You should only
run it if you trust the publisher and the website requesting it."
Do I go back to the 32 bit IE, go to the update page, click the button to
let this ActiveX control run, then hopefully take another shot at that
"Update" button in the top right corner of that page and expect the program
to accurately scam my machine (now with IE 32 bit) and get a list of updates
needed just for my machine?
news:eoEeZWZyJHA.1196@TK2MSFTNGP03.phx.gbl...
> >>run WinUpdate<<
> to be a catalog of downloads. The dominant product was Office 2007 but
> there were others listed on the side including my 2003. Because I saw
> nothing with the word "update" - only "download" - I thought this might be
> (incorrectly now) another download of what I already put on the machine.
> (I don't think clearly beyond 1 AM :)). Anyway... I decided that I should
> probably just install the next disc and maybe it would be cleared with its
> subsequent update routine. You know the rest. This is obviously where I
> failed. That Framework stuff is somewhere on that page I assume.
> have been what I should have been dealing with - that I dismissed because
> I say something that appeared to be a mini program with "2006" in its
> title. At 1 AM my mind said "that's a program later than 2003 so so it
> can't be something that belongs to whatever I'm supposed to be finding".
> So I dismissed the lot and installed disc 2.
> things will be clearer. When I pressed that "Update" button at the top of
> the page I was taken to, I expected a list that would jump out at me.
> Instead, I became confused. I'll try again now and report back.
> > see if it gives any Office updates.
> >> sent up a second window entitled "Program Compatibility Assistant". It
> >> read:
> >> platform."
> >> problem was caused by a compatibility issue between this version of
> >> Windows and this version of Microsoft.NET Framework 1.1. This program
> >> was created by Microsoft Corporation.
> >> closed itself:
> >> to be upgraded exists on your computer and that you have a correct
> >> upgrade patch."
> >> that Vista will attempt to update itself around 3AM but I'm hopeful it
> >> has enough artificial intelligence to realize something 's in progress
> >> and it won't gum up the works.
> >> installation.
L
Luther Blissett
> process:
> to the right:
> "jaygreg" <jaygre...@hotmail.com> wrote in message
> >>>run WinUpdate<<
> > nothing with the word "update" - only "download" - I thought this mightbe
> > (incorrectly now) another download of what I already put on the machine..
> > can't be something that belongs to whatever I'm supposed to be finding"..
> > "DL" <notva...@spoofaddress.co.uk> wrote in message
> >>> I installed the first disc successfully on the new Vista machine then-
> >>> read:
> >>> platform."
> >>> closed itself:
> >>> upgrade patch."
> >>> installation.-
One compatibility issue you'll run into is with Sql Server. BCM for
Office 2003 used Sql Server 2000, which is incompatible with Vista.
There's a BCM Service Pack, BCM v2 SP4, that installs a version of Sql
Server 2005 that's compatible with Vista, and has other fixes to allow
BCM to run with Vista's tigher permissions.
That said, Vista was released four years after Office 2003, so you
might consider updating to Office 2007, which was designed with Vista
in mind.
S Email Generated from another program and then edited sends original email. Using Outlook 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
R SearchPublicFolders program Outlook VBA and Custom Forms 1
Diane Poremsky To Change the Default E-mail Program in Windows Using Outlook 0
I There is no email program associated to perform requested action Using Outlook 0
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
J My Outlook program has stopped receiving. I can still send Using Outlook 1
C New version of MFCMAPI program Using Outlook 0
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
A outlook 2007 - there is no email program associated ... Using Outlook 3
F Default Program for Opening .pst Files ? Using Outlook 6
A Outlook-Program Not Closing Properly Using Outlook 10
B How to remove an old program from the Tools dropdown? Using Outlook 7
D How to set permissions to allow external program to send an email? Using Outlook 0
T getting an error This file does not have a program associated with it for performing this action. C Using Outlook 7
N The add-in "C:\program files\google\google desktop search\googledesktopO..." could not be installed Using Outlook 32
R Access Program Only Looping Part Way Through Outlook Inbox Outlook VBA and Custom Forms 2
M Allow or Deny when a Program tries to send an email Outlook VBA and Custom Forms 1
R how to (re)set the default data file for Outlook in a VB program Outlook VBA and Custom Forms 2
J Program won't end in Win7 Outlook VBA and Custom Forms 1
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
S Email Organizer Program Outlook VBA and Custom Forms 2
G GAL program acces in outlook 2007 Outlook VBA and Custom Forms 2
H Program "Click on Ribbon Button" Using VBA Outlook VBA and Custom Forms 1
H Program email save as text file Outlook VBA and Custom Forms 5
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
N How to attach a file with MS Outlook, from a program? Outlook VBA and Custom Forms 3
Q why this program doesn't work if Outlook is not manually launched? Outlook VBA and Custom Forms 4
V how to switchoff program access message in outlook 2003 Outlook VBA and Custom Forms 1
V "A program has attachment filename open" Message returns Outlook VBA and Custom Forms 4
Diane Poremsky Say No! to Compatibility Mode Using Outlook 0
P Compatibility Checker Message in Outlook 2013 Using Outlook 1
G Outlook 2007 Forms Compatibility Issues Using Outlook 0
C Compatibility with Windows 7 BCM (Business Contact Manager) 1
J Outlook '07 with BCM compatibility BCM (Business Contact Manager) 1
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
