Compile error: Object required
brookh
I'm trying to write a macro for Outlook 2007, and getting nonsensical compile
errors. For example: The following script results in "Compile error: Object
required"
Sub TestScript()
Dim x As Integer
Set x = 2
Am I doing something wrong or is my Outlook VBA just broken?
brookh
RE: Compile error: Object required [ANSWER]
The "object required" error refers to the "Set" statement, which is only used
for assigning objects. When assigning simple variables, do not use "Set". The
correct code is:
Sub TestScript()
Dim x As Integer
' Set x = 2 results in "Compiler error: Object required"
x = 2
> required"
> Sub TestScript()
> Dim x As Integer
> Set x = 2
> End Sub
Michael Bauer
The Set statement is used only for object variables; but you have declared x
as Integer, so x=2 would do it.
Best regards
Michael Bauer
Am Sat, 13 Jun 2009 10:36:01 -0700 schrieb brookh:
compile
Object
> required"
> Sub TestScript()
> Dim x As Integer
> Set x = 2
> End Sub
C compile error on previously functioning code outlook 2003 windows Outlook VBA and Custom Forms 1
P Compile error.. Outlook VBA and Custom Forms 3
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 5
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error Using Outlook 0
Diane Poremsky RMS Error: System clock has been tampered with Using Outlook 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
K Error: Paper Size Invalid Using Outlook 0
