Memory with MailItem.Send
N
Nathan
I'm sending all the messages contained in a particular folder when Outlook
launches. This can be as many as 500 messages.
Watching Outlook.exe in task manager, as each message is sent, the Mem Usage
slowly balloons from 24MB at start to 116MB just before crashing.
I have tried many different ways of setting my MailItem instances to
Nothing. I've also tried moving the sending code to a seperate Sub in the
hopes that garbage collection would release each MailItem from memory after
being sent. Nothing has worked.
What is the correct way to use VBA to sent a MailItem and then release it
from memory before sending the next?
I can post my code if that'll help, but I'm hoping this situation has come
up before and there is a simple solution that I've been unable to find.
Thanks for any feedback.
G "Cannot load GUI library into memory" Outlook VBA and Custom Forms 3
A active inspector in memory Outlook VBA and Custom Forms 1
M Not enough free memory BCM (Business Contact Manager) 11
C Business Contact Manager and Outlook 2007 "not enough free memory BCM (Business Contact Manager) 5
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
R Outlook staying in memory Outlook VBA and Custom Forms 2
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
L Out of memory errors and Auto-linking hangs BCM (Business Contact Manager) 2
R Out of memory when click History button BCM (Business Contact Manager) 2
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
