Data validation
F
Fred Boer
Hi!
Well, I am considering how to deal with data validation. I am able to use
the data validation that is available through the Properties sheet. It
appears, however, that the error message popup message is delayed until
saving changes. A couple of questions:
1. Is there a way to limit data entry in a combobox to the "Possible
Values"? Something similar to the "LimitToList" property in Access
comboboxes?
2. Is the built in validation the only available option? Can we do it using
VBA and events?
Fred Boer - Amateur Access Enthusiast
Interests: Library software / Z39.50 / Web Services
Freeware Small Library Application available here:
http://www3.sympatico.ca/lornarourke/
Sue Mosher [MVP]
Are you referring to an Outlook custom form? If so, on the Advanced
Properties dialog for the control, does the MatchRequired property fit your
scenario for #1?
Doing validation with VBA events would mean distributing that VBA code to
each user, for which there isn't a good supported method. If you need to
validate as the user enters data, see
http://www.outlookcode.com/article.aspx?ID=38 for available form code
events.
Sue Mosher
"Fred Boer" <fredboer1@NOyahooSPAM.com> wrote in message
news:uXIgWCF%23JHA.4560@TK2MSFTNGP03.phx.gbl...
> Hi!
> comboboxes?
> using VBA and events?
> Thanks
F
Fred Boer
Hello Sue:
Although I've only been working with Outlook for a week or two, it's seems
obvious that you are one of the gurus in this field! Thanks for your help.
Yes, the "MatchRequired" advanced property does seem to be what I need. A
follow up question, however: where the heck in the Outlook Help system can I
get information on these advanced properties? I've spent about half an hour
trying everything I can think of but can't find anything.
With respect to my VBA question, I must apologize for my careless use of
terms. I think what I meant to say was "VBScript" not "VBA". I meant to
refer to the programming environment used by Outlook. The question rephrased
would be, perhaps, "Is it common/possible to use code in VBScript to do data
validation on custom form fields?"
Thanks again!
Fred
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:OeYyfaG%23JHA.3612@TK2MSFTNGP04.phx.gbl...
> your scenario for #1?
> events.
> > Sue Mosher
> > Hi!
> > comboboxes?
>> Thanks
Sue Mosher [MVP]
To get to the Outlook Developer Help, open the VBA window and press F1. It's
also available online at MSDN.
Outlook has two programming environments -- VBScript for code behind Outlook
forms and VBA for macros and application-level event handlers. Information
on using VBScript to handle users' interaction with the controls on the
form, including validation, is at the link I posted earlier.
Sue Mosher
"Fred Boer" <fredboer@NOyahooSPAM.com> wrote in message
news:%23NXRIZL%23JHA.200@TK2MSFTNGP05.phx.gbl...
> Hello Sue:
> I get information on these advanced properties? I've spent about half an
> hour trying everything I can think of but can't find anything.
> rephrased would be, perhaps, "Is it common/possible to use code in
> VBScript to do data validation on custom form fields?"
> Thanks again!
> Fred
> > events.
> >> Hi!
> >> use the data validation that is available through the Properties sheet.
> >> It appears, however, that the error message popup message is delayed
> >> until saving changes. A couple of questions:
> >> comboboxes?
>>> Thanks
F
Fred Boer
Thanks again. I have (finally) figured out how to find what I needed in
Outlook help. I was looking in the "Microsoft Outlook Visual Basic
Reference", but the help I needed was in "Outlook - Forms> Control
Reference".
The question I'd like to ask the developers of the Help system is: "Why the
heck when I type "MatchEntry" in the search textbox, is nothing found!?".
Surely you should be able to enter the name of any property/method/object
and be linked to help entries for that item....
Cheers!
Fred
news:%23l%23N5mL%23JHA.1340@TK2MSFTNGP05.phx.gbl...
> It's also available online at MSDN.
> Outlook forms and VBA for macros and application-level event handlers.
> Information on using VBScript to handle users' interaction with the
> controls on the form, including validation, is at the link I posted
> earlier.
> > Sue Mosher
> > Hello Sue:
> > seems obvious that you are one of the gurus in this field! Thanks for
> > your help.
> > can I get information on these advanced properties? I've spent about half
> > an hour trying everything I can think of but can't find anything.
>> Thanks again!
>> Fred
> >> to each user, for which there isn't a good supported method. If you need
> >> to validate as the user enters data, see
> >> events.
> >>> Hi!
> >>> comboboxes?
>>>> Thanks
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
Diane Poremsky How to Compact the Data File When you Close Outlook Using Outlook 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
Diane Poremsky Rename Email Accounts and Data Files in the Folder List Using Outlook 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
M Dilemma: to add to existing data file or not to? Using Outlook 16
R Exporting Excel data to Outlook 2016 Calendar Outlook VBA and Custom Forms 20
Diane Poremsky Data loss may occur during public folder migration Using Outlook 0
A How to export one email data to excel Using Outlook 1
Diane Poremsky Create Appointments Using Spreadsheet Data Using Outlook 0
S Outlook data file cannot be accessed message Using Outlook 5
L outlook data file confusion Using Outlook 1
M Extracting cell data from table Outlook VBA and Custom Forms 2
