Hi, Ken, What should be noticed to avoid memory leak in outlook addin?
ryotyankou
Hi, Ken, thanks for your help so far, and i can work with my outlook addin
now, but it still have some troubles. I have three toolbar, host, editor and
viewer dialog, in ATL, VC2005, outlook2003. I use CComPtr and CComQIPtr to
process interfaces. Now it is a quite strange that if i open e-mails or
create new ones and then close them. The outlook then seems become sluggish.
This only happen in word editor mode. I do nothing specially, only hide all
other created toolbar(if it is in editor dialog)after create the toolbar. I
check my code again and again but couldn't find any useful informations why
it become sluggish, any sugguestions? Thank you. Ken.
K
Ken Slovak - [MVP - Outlook]
There's no way I can tell what's going on, and I don't do C++/ATL
programming. You need to run the debugger and see what processes are
consuming CPU cycles and to profile your code to see if any of it is the
cause of the problem.
"ryotyankou " <u48591@uwe> wrote in message
news:9850b33529a73@uwe...
> and
> sluggish.
> all
> I
> why
ryotyankou
Hi, ken, i found that memory leak should be generated by resource files. I
use bitmap file and use PasteFace to set button image. But if i set all
button in text style(msoButtonCaption), the "memory is not enought" dialog
will not show then. Are there something i should notice while using bitmap as
resource? My process is load resource from RC file, save it in clipboard,
close clipboard, then delete the resource, and call PasteFace. Any idea?
> [quoted text clipped - 10 lines]
> > why
K
If that causes a memory leak then you're not releasing all the resources
you've instantiated. I don't know how you're doing the code but if you
create any DC's (device contexts) they must be deleted as must anything else
such as memory bitmaps.
news:986a9cd6d55d1@uwe...
> as
R Hi, ken, GetState problem again, come in this post please? Outlook VBA and Custom Forms 4
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
F Which upgrade should I go for and how do I do it please? Using Outlook 2
E Should I switch to IMAP? Using Outlook 0
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Unhandled exception: picture argument should be an image BCM (Business Contact Manager) 0
E Should I switch to redemption Outlook VBA and Custom Forms 11
O Third-party VSTO 2005 SE plug-in for Outlook 2007: what should I signwith a publisher certificate? Outlook VBA and Custom Forms 3
R Which event should i advise? Outlook VBA and Custom Forms 2
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
Q Re: Detecting whether a toolbar is and should be shown Outlook VBA and Custom Forms 5
J 14 Steps To Building Your Bulk Emails So They Get Noticed New Slipstick.com Articles 0
