Add Multiple Attachments Sources using VBA in Word
JBark
How can this code be written to add multiple attachments using vba and Word
as my email editor. The first attachment is the active document itself, the
other 4 attachments have their full path names stored in a field in the
document. This is what I have but I'm getting a syntax error and I'm not sure
why. Any suggestions are greatly appreciated.
> Attachments.Add Source:=ActiveDocument.FullName, Type:=olByValue, _
> Add Source:=ActiveDocument.TextBox("TextBoxFile1").Result,
Type:=olByValue, _
> Add Source:=ActiveDocument.TextBox("TextBoxFile2").Result,
Type:=olByValue, _
> Add Source:=ActiveDocument.TextBox("TextBoxFile3").Result,
Type:=olByValue, _
> Add Source:=ActiveDocument.TextBox("TextBoxFile4").Result,
Type:=olByValue
> Send
Sue Mosher [MVP]
You need a separate .Attachments.Add statement for each attachment, not one
long statement with multiple calls to the .Add method.
Sue Mosher
"JBark" <JBark> wrote in message
news:B6DFBA55-0410-444F-8A4B-1FE91DAD0B3C@microsoft.com...
> Hi,
> Word
> the
> sure
> .Attachments.Add Source:=ActiveDocument.FullName, Type:=olByValue, _
> .Add Source:=ActiveDocument.TextBox("TextBoxFile1").Result,
> Type:=olByValue, _
> .Add Source:=ActiveDocument.TextBox("TextBoxFile2").Result,
> Type:=olByValue, _
> .Add Source:=ActiveDocument.TextBox("TextBoxFile3").Result,
> Type:=olByValue, _
> .Add Source:=ActiveDocument.TextBox("TextBoxFile4").Result,
> Type:=olByValue
> .Send
JBark
Yes - I had tried that also like this, but I'm still getting syntax error.
> Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile1").Result,
Type:=olByValue, _
> Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile2").Result,
Type:=olByValue, _
> Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile3").Result,
Type:=olByValue, _
> Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile4").Result,
Type:=olByValue
> Send
> > Sue Mosher
> > Hi,
> > Word
> > the
> > sure
> > Type:=olByValue, _
> > Type:=olByValue, _
> > Type:=olByValue, _
> > Type:=olByValue
> > .Send
Sue Mosher [MVP]
This is still all one statement, because of the underscore continuation
characters at the end of the first four lines.
Sue Mosher
news:E7B89599-FD4F-4E32-9052-569B27FBB3CB@microsoft.com...
> .Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile1").Result,
> Type:=olByValue, _
> .Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile2").Result,
> Type:=olByValue, _
> .Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile3").Result,
> Type:=olByValue, _
> .Attachments.Add Source:=ActiveDocument.TextBox("TextBoxFile4").Result,
> Type:=olByValue
> .Send
> > one
> > > Hi,
> > > Word
> > > the
> > > not
> > > sure
> > > Type:=olByValue, _
> > > Type:=olByValue, _
> > > Type:=olByValue, _
> > > Type:=olByValue
> > > .Send
JBark
Thanks Sue. The code runs fine without any errors and attaches the original
doc but not the additional docs. Should I ask someone over in the Word Forum
about this? Or do you have a suggestion as to why the additional files will
not attach?
Sue Mosher [MVP]
If you have already made the change I suggested -- removing the extraneous
underscore characters so that you have each Attachments.Add call in a
separate statement -- I would suggest looking at the actual value of what
you're getting from the ActiveDocument.TextBox("TextBoxFile1").Result
expressions.
Sue Mosher
news:F602CE82-F4CD-4545-8F73-AC8A8BCC8A77@microsoft.com...
> original
> Forum
> will
> not attach?
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:Obl0OZN%23JHA.2824@TK2MSFTNGP03.phx.gbl...
> > error.
> > .Attachments.Add
> > Type:=olByValue, _
> > .Attachments.Add
> > Type:=olByValue, _
> > .Attachments.Add
> > Type:=olByValue, _
> > .Attachments.Add
> > Type:=olByValue
> > .Send
> >> one
> >> > Hi,
> >> > Word
> >> > itself,
> >> > the
> >> > the
> >> > not
> >> > sure
> >> > _
> >> > Type:=olByValue, _
> >> > Type:=olByValue, _
> >> > Type:=olByValue, _
> >> > Type:=olByValue
> >> > .Send
JBark
Yes - I kept digging and I was declaring the fields as formfields but they're
really textboxes. It works now like this:
> Attachments.Add Source:=ActiveDocument.TextBoxFile1.Value,
Type:=olByValue
> Attachments.Add Source:=ActiveDocument.TextBoxFile2.Value,
Type:=olByValue
> Attachments.Add Source:=ActiveDocument.TextBoxFile3.Value,
Type:=olByValue
> Attachments.Add Source:=ActiveDocument.TextBoxFile4.Value,
Type:=olByValue
> Send
Thanks a bunch for your help!
> expressions.
> > Sue Mosher
> > original
> > Forum
> > will
> > not attach?
> >> error.
> >> .Attachments.Add
> >> Type:=olByValue, _
> >> .Attachments.Add
> >> Type:=olByValue, _
> >> .Attachments.Add
> >> Type:=olByValue, _
> >> .Attachments.Add
> >> Type:=olByValue
> >> .Send
> >>> one
> >>> > Hi,
> >>> > Word
> >>> > itself,
> >>> > the
> >>> > the
> >>> > not
> >>> > sure
> >>> > _
> >>> > Type:=olByValue, _
> >>> > Type:=olByValue, _
> >>> > Type:=olByValue, _
> >>> > Type:=olByValue
> >>> > .Send
Z bulk add categories / with fixed colours / select multiple categories on a not Using Outlook 1
R Add multiple individuals as meeting organizer Using Outlook 4
K 2003 Outlook Contacts - how do I add text to multiple contacts .... Outlook VBA and Custom Forms 2
J OL add-In for multiple versions Outlook VBA and Custom Forms 1
U Not able to delete Add-in button from multiple Outlook Explorer Outlook VBA and Custom Forms 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
B Task Filter Not Working When I add too many criteria Using Outlook 0
