Run A Script not listed in rules wizard
L
laavista
I'm using Outlook 2003. I purchased an Outlook VBA book, and it shows
examples of using the rules wizard "run a script". I do not see this option
when I go into rules, and I would really like to use it.
Any suggestions?
Thanks, in advance, for your help.
Alan Moseley
In Rules and Alerts click New Rule
Click 'Start From A Blank Rule' and choose a Step 1 option. Click Next
Select one or more conditions and click 'Next'
Under Select Action you should see an option for 'Run A Script', check it
and click on the 'a script' hyperlink in the bottom window.
Choose the script that you wish to run.
Continue the remainder of the wizard.
Alan Moseley IT Consultancy
http://www.amitc.co.uk
If I have solved your problem, please click Yes below. Thanks.
> Any suggestions?
L
laavista
STILL IS NOT AVAILABLE... Run A Script not listed in rules wizard
I went through the steps you outlined multiple times, and there's no "run a
script" rule. I wonder if my company "turned off" this option?
I was hoping to use this as the VBA procedure I wrote results in the Outlook
Security Warning and is useless because of the warnings (my user would have
to click 'yes' 400+ times a month). I thought by using the RunAScript rule
it may prevent the warnings.
Thanks for responding.
> > Any suggestions?
Sue Mosher [MVP]
Re: STILL IS NOT AVAILABLE... Run A Script not listed in rules wizard
Are you trying to create a rule for outgoing messages? The "run a script"
action is available only for incoming messages.
If you're getting security prompts with normal Outlook VBA code, using the
"run a script" rule isn't necessarily going to get around that. Maybe your
VBA code simply isn't constructed properly to derive all objects from the
intrinsic Application object. You might also want to tell us the security
state shown on the Help | About Microsoft Outlook dialog.
Sue Mosher
"laavista" <laavista> wrote in message
news:BD9B4898-5CA5-4993-B9C0-690935DEECF1@microsoft.com...
> Outlook
> have
> rule
> > > option
Alan Moseley
RE: STILL IS NOT AVAILABLE... Run A Script not listed in rules wizard
If your script is written within Outlook VBA then it should be possible to
write your code so that the warnings do not appear. Do you have any lines of
code similar to:-
Set objOutlook = New Outlook.Application
or
Set objOutlook = CreateObject("Outlook.Application")
If so then try changing this to:-
Set objOutlook=Outlook
If you then create further objects from this, such as:-
Set objNamespace = Outlook.GetNameSpace("MAPI")
Set objContacts = objNamespace.GetDefaultFolder(olFolderContacts).Items
and so on, you will prevent the security warning from being shown as
'Outlook' is an in-built object that picks up a reference to the currently
running Outlook application.
If you need any further assistance then post your code and I will see what
needs changing.
> > > > Any suggestions?
L
laavista
Alan, you do not know how much I appreciate you looking at my code to see if
the security warnings can be eliminated. I REALLY need to get this working
and have spent hours (and hours) trying things, researching, and trying more
things, with no luck. THANK YOU.
The reason I need this-- I have several users who send 400+ emails a month
to customers with attachments. In order for their billing reconciliation to
match, they have to remember to send a copy of these emails WITHOUT the
attachments to the billing personnel who runs a reconciliation procedure to
match emails sent to customers against a database. If the user forgets to
send the email (they reply with different addressees so the attachments are
not sent), then it causes a reconciliation check, an email has to be sent to
the user asking for a copy of the email, the user has to send it and someone
tracks that it's received. My intent: after the user sends the email to
their customer, the rules wizard would automatically move the sent email
(based on words in the subject) to a folder, then the sub procedure would run
sending a reply to the appropriate billing people.
My code:
CODE IS IN "THISOUTLOOK SESSION"
Option Explicit
Dim WithEvents ReplyToItItems As Items
Dim ns As Outlook.NameSpace
Set ns = Application.GetNamespace("MAPI")
Set ReplyToItItems = ns.Folders.Item("Personal
Folders").Folders.Item("test").Items
Sub ReplyToItItems_ItemAdd(ByVal Item As Object)
' when a new item is added to "test folder" it is processed
Dim myReply As MailItem
Set myReply = Item.Reply
With myReply
> To = "whoever@abc.com"
> Send
Private Sub application_quit()
Set ReplyToItItems = Nothing
Set ns = Nothing
> code similar to:-
> or
> needs changing.
> > > > > > Any suggestions?
Sue Mosher [MVP]
Did you check your security state yet? If it says "administrator
controlled," that means that the Exchange administrator is controlling
security and, unless they loosen it for you, you won't be able to run VBA
code without security prompts.
Sue Mosher
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:OS7F08r$JHA.5068@TK2MSFTNGP03.phx.gbl...
> >a
> > Outlook
> > have
> > rule
> >> it
> >> > shows
> >> > option
Alan Moseley
Your code works perfectly on my stand-alone Outlook. I fear therefore that,
as Ms Mosher has already suggested, that the Outlook security has been
tightened up by your administrators.
Do you have to email this reply to the billing people? If you are running
Exchange server, could the email be copied to a public folder perhaps? This
shouldn't trigger the security prompts. Your code could be easily modified
to do this. Failing that, if you have Visual Studio, could you convert this
code to run via an Outlook Addin?
> My code:
> Option Explicit
> Private Sub Application_Startup()
> End Sub
> With myReply
> .To = "whoever@abc.com"
> .Send
> End With
> End Sub
> Set ns = Nothing
> End Sub
> > code similar to:-
> > or
> > needs changing.
> > > > > > > > Any suggestions?
L
laavista
You might have an idea-- to copy it to a public folder. I would have to
figure out how to copy it without the attachments, though. (I'm VERY new to
Outlook VBA). I'll see if I can figure out how to do that.
Alan, THANK YOU, for taking the time to look at my code. It really helped.
I thought perhaps that I coded something incorrectly. REALLY appreciate it.
> > My code:
> > Option Explicit
> > End Sub
> > With myReply
> > .Send
> > End With
> > End Sub
> > Set ns = Nothing
> > End Sub
> > > code similar to:-
> > > or
> > > needs changing.
> > > > > > > > > > Any suggestions?
Alan Moseley
Does this help?
Public Sub SaveACopy(objMailItem As MailItem)
Dim objMailCopy As MailItem
Dim objNamespace As NameSpace
Dim objPublicFolder As MAPIFolder
Dim objAttachment As Attachment
Set objMailCopy = objMailItem.Copy
Set objNamespace = Outlook.GetNamespace("MAPI")
Set objPublicFolder = objNamespace.Folders("Public Folders")
Set objPublicFolder = objPublicFolder.Folders("All Public Folders")
Set objPublicFolder = objPublicFolder.Folders("Insert Your Folder Name")
With objMailCopy
If .Attachments.Count > 0 Then
For Each objAttachment In .Attachments
objAttachment.Delete
objMailCopy.Save
objMailCopy.Move objPublicFolder
Set objMailCopy = Nothing
Set objPublicFolder = Nothing
Set objNamespace = Nothing
> > > > My code:
> > > > Option Explicit
> > > > End Sub
> > > With myReply
> > > .Send
> > > End With
> > > > End Sub
> > > Set ns = Nothing
> > > End Sub
> > > > code similar to:-
> > > > or
> > > > needs changing.
> > > > > > > > > > > > Any suggestions?
Sue Mosher [MVP]
Don't move the copy until you've finished deleting the attachments. Also,
deleting inside a For Each ... Next loop won't work because each deletion
resets the index. Use a down-counting loop instead:
With objMailCopy
count = .Attachments.Count
For i = count to 1 Step -1
Set objAttachment = .Attachments(i)
objMailCopy.Save
Sue Mosher
"Alan Moseley" <AlanMoseley> wrote in message
news:7DCDAAD4-8793-4338-94A5-7B2723435556@microsoft.com...
> Does this help?
> Name")
> With objMailCopy
> Next
> End If
> objMailCopy.Save
> End With
> End Sub
> > new to
> > helped.
> > it.
> > > that,
> > > running
> > > This
> > > modified
> > > this
> > > > see if
> > > > working
> > > > trying more
> > > > month
> > > > reconciliation to
> > > > the
> > > > procedure to
> > > > forgets to
> > > > attachments are
> > > > sent to
> > > > someone
> > > > email to
> > > > email
> > > > would run
> > >> > > My code:
> > >> > > Option Explicit
> > >> > > End Sub
> > > > With myReply
> > > > .Send
> > > > End With
> > >> > > End Sub
> > > > Set ns = Nothing
> > > > End Sub
> > > > > possible to
> > > > > any lines of
> > > > > code similar to:-
> > > > > or
> > > > > Set objContacts =
> > > > > as
> > > > > currently
> > > > > see what
> > > > > needs changing.
> > > > > > no "run a
> > > > > > the Outlook
> > > > > > would have
> > > > > > RunAScript rule
> > > > > > > Click Next
> > > > > > > Script', check it
> > > > > > > > and it shows
> > > > > > > > see this option
> > > > > > >> > > > > > > Any suggestions?
L
laavista
Alan, this was VERY helpful!! Again, thank you so much. You have saved me
hours.
> Does this help?
> With objMailCopy
> Next
> End If
> objMailCopy.Save
> End With
> End Sub
> > > > > > My code:
> > > > > > Option Explicit
> > > > > > End Sub
> > > > With myReply
> > > > .Send
> > > > End With
> > > > > > End Sub
> > > > Set ns = Nothing
> > > > End Sub
> > > > > code similar to:-
> > > > > or
> > > > > needs changing.
> > > > > > > > > > > > > > Any suggestions?
L
laavista
THANK YOU for your help with this!!! I appreciate your time!
> With objMailCopy
> Next
> End With
> objMailCopy.Save
> > Sue Mosher
> > Does this help?
> > Name")
> > With objMailCopy
> > Next
> > End If
> > objMailCopy.Save
> > End With
> > End Sub
> >> new to
> >> helped.
> >> it.
> >> > that,
> >> > running
> >> > This
> >> > modified
> >> > this
> >> > > see if
> >> > > working
> >> > > trying more
> >> > > month
> >> > > reconciliation to
> >> > > the
> >> > > procedure to
> >> > > forgets to
> >> > > attachments are
> >> > > sent to
> >> > > someone
> >> > > email to
> >> > > email
> >> > > would run
> >> > >> > > My code:
> >> > >> > > Option Explicit
> >> > >> > > End Sub
> >> > > With myReply
> >> > > .Send
> >> > > End With
> >> > >> > > End Sub
> >> > > Set ns = Nothing
> >> > > End Sub
> >> > > > possible to
> >> > > > any lines of
> >> > > > code similar to:-
> >> > > > or
> >> > > > Set objContacts =
> >> > > > as
> >> > > > currently
> >> > > > see what
> >> > > > needs changing.
> >> > > > > no "run a
> >> > > > > the Outlook
> >> > > > > would have
> >> > > > > RunAScript rule
> >> > > > > > Click Next
> >> > > > > > Script', check it
> >> > > > > > > and it shows
> >> > > > > > > see this option
> >> > > > > > >> > > > > > > Any suggestions?
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
E run script fails suddenly Using Outlook 3
L Run script rule not exectued for first few mails Outlook VBA and Custom Forms 2
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
J VBA Run When Reply Outlook VBA and Custom Forms 4
