Newmail macro
Swapnil G.
I have a Outlook macro that checks for perticular words on receiving new
mail. If that word is found, it desplays a msg in msgbox. see below the code;
Private Sub Application_NewMail()
Dim oNS As NameSpace
Dim oFolder As MAPIFolder
Dim oItem As Object
Dim oNewMail As MailItem
Dim var As Variant
Set oNS = GetNamespace("MAPI")
Set oFolder = oNS.GetDefaultFolder(olFolderInbox)
Set oNewMail = oFolder.Items.GetLast
With oNewMail
'MsgBox .Subject & " " & .SenderName
For Each var In Array("Good Work", "Great Job", "Excellent", "Great
Work", "Keep it up", "Very Good")
If InStr(1, .Body, var, vbTextCompare) <> 0 Then
MsgBox "Congrats! " & .ReceivedByName & " Your work just got
appriciated by " & .SenderName, vbOKOnly
MsgBox "Go ahead and record it in CED. ", vbOKOnly
This code work fine. However I am getting a weird problem. When I lock and
then unlock my PC, an error msg pops up 'Run-time error 13: Type mismatch'
and on clicking 'debug' button it points out to line " Set oNewMail =
oFolder.Items.GetLast" in above code. Even if I click 'cancel' button, it
opens VBA editior.
Can somebody help me to get rid of this bug please?
K
Ken Slovak - [MVP - Outlook]
Maybe that item isn't a mail item? Get it as an Object and test for
item.Class to see if it really is an email item.
Also, NewMail() is hardly the best event to use, it misses things and only
fires at intervals. Use NewMailEx(), which provides a delimited list of
EntryID's for every item that's come in since the last time that event
fired.
"Swapnil G." <Swapnil G.> wrote in message
news:AC1D5845-FF08-4A81-82D2-E552C024BAB9@microsoft.com...
> code;
> Dim oItem As Object
> Dim var As Variant
> With oNewMail
> got
> End If
> Next
> End With
> End Sub
> opens VBA editior.
M Extract text in existing message body for use in newmail items Using Outlook 17
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
G VBA Macro Using Outlook 4
