edit right pane of mail
Ashish
Is it possible to edit mail right pane in outlook addin? When select a mail
in outlook right pane shows its field like subject,date body,attachments
etc.
Can we show some extra information in right pane when select a mail. Which
event is call when show right pane(select mail) for any mail
mightyCoCo
> etc.
if i got it right, you refer to the preview pane of an email.
What Outlook version?
Look into the Explorer.SelectionChanged event. this is triggered, when
an item was selected.
You may be able to modify certain information's in the selected item.
Ashish
Thanks explorer.selectionChanged is called when switch an item or folder. It
also call when we select multiple items. I want to show some info in preview
pane when a single item is selected not for multiple selected items . But in
explorer.selectionChanged function Explorer->Selection->Count always returns
0. So i am not able to access selected item. Please suggest how to access
selected item. Why it always gives 0 as Count. Outlook version is 2003.
"mightyCoCo" <mightycoco@googlemail.com> wrote in message
news:5d351c66-3e09-4e9c-babf-1d24e0f81a0a@d4g2000vbm.googlegroups.com...
> mail
> etc.
Ashish
Sorry i get correct selected item
To make change in preview window should i add info to mail or we can
directly change preview window? Is it editable
> mail
> etc.
mightyCoCo
> "mightyCoCo" <mightyc...@googlemail.com> wrote in message
> > mail
> > etc.
You could change the body of the eMail. But this change would be
persistent.
I don't know of a clean way to show a temporarily modified body.
You would need to save the original mail somewhere else and restore
it, when the selection changes.
If you need to have more fields net to subject/date etc, that might be
possible with custom forms. But I've never done this. Maybe someone
else has some insights / tips...
K
Ken Slovak - [MVP - Outlook]
Custom forms won't display in the reading pane for the most part, and the
reading pane is not editable or modifiable. You'd have to create your own
window and overlay that over the reading pane using Win32 API calls, which
is not only tricky but has the potential to crash Outlook and even Windows
if you don't know what you're doing.
news:cd628338-dd25-45c9-b368-460e99b36f22@g31g2000yqc.googlegroups.com...
> > mail
> > etc.
> > Which
persistent.
Ashish
Thanks Ken, Thanks Mighty
I got it now. To show something in reading pane we need to make change in
mail. Without making change in mail we cant show anything extra in reading
pane as reading pane is not editable.
Well if a mail has attachment it shows an icon for it with subject in
outlook explorer. If any mail has no attachment then can we show
same/anyother icon at same place(after subject) using some programming. Is
it possible?
I did not see any property for this icon in outspy/MFCMAPI.
news:%23P$$S1oGKHA.4956@TK2MSFTNGP03.phx.gbl...
> > > mail
> > > body,attachments
> > > etc.
> > > Which
> persistent.
mightyCoCo
> it possible?
> " - " <kenslo...@mvps.org> wrote in messagenews:%23P$$S1oGKHA.4956@TK2MSFTNGP03.phx.gbl...
> >news:cd628338-dd25-45c9-b368-460e99b36f22@g31g2000yqc.googlegroups.com....
> >>news:5d351c66-3e09-4e9c-babf-1d24e0f81a0a@d4g2000vbm.googlegroups.com....
> >> > Is it possible to edit mail right pane in outlook addin? When selecta
> >> > mail
> >> > body,attachments
> >> > etc.
> >> > Which
> > persistent.
Look at the MailItem.Attachments method to add attachements to the
MailItem.
You can generate the attachement on the fly and add it as a binary
stream or write it on disk and give the Attachemts.Add function the
path to this file on disk.
You'd need to use the MailItem.Save method if you are finished to not
loose your changes.
K
The InfoBar is also not modifiable or exposed. What could be done possibly
is to use the model for previewers (like for previewing PDF attachments in
the reading pane) to display custom information. That would be Outlook 2007
only or later, and I'm not sure it's actually doable. I've never played with
that for that purpose, only for an actual previewer. But it's the only
possibility I can think of.
"Ashish" <akohli_2004@hotmail.com> wrote in message
news:urRr%23XpGKHA.4416@TK2MSFTNGP04.phx.gbl...
> it possible?
Ashish
So if we need to show attachment icon in a mail which has no attachment then
we need add an extra attachment.
What about outlook objects? I think using outlook Objects we can make change
locally for a user not on exchange server. Is it possible to change mail
view using outlook object model? Is there any link how to use outlook
objects in outlook addin?
> it possible?
> " - " <kenslovak@mvps.org> wrote in message
> > which is not only tricky but has the potential to crash Outlook and even
> > Windows if you don't know what you're doing.
> >> > mail
> >> > body,attachments
> >> > etc.
> >> > Which
> > persistent.
K
You can change the view by setting the Explorer.CurrentView object to the
view you want. You can also create a new view using XML and set that.
Of course you can work with Outlook objects in an Outlook addin, just use
the Outlook object model. How else do you think you'd work with Outlook
objects? You can look at the Object Browser Help as well as at Web sites
such as www.outlookcode.com for lots of Outlook object model code samples.
news:%23Wim291GKHA.4168@TK2MSFTNGP05.phx.gbl...
> then we need add an extra attachment.
> change locally for a user not on exchange server. Is it possible to change
> mail view using outlook object model? Is there any link how to use outlook
Ashish
Yes we can create/change view using XML. But how to add attachment
icons/name in XML? Is there any example available?
What's advantages of using Outlook object model?
Can we also change view using Outlook object model
news:OCyE673GKHA.4620@TK2MSFTNGP02.phx.gbl...
> > change mail view using outlook object model? Is there any link how to use
> > outlook objects in outlook addin?
K
You can't add anything to an XML view that's not supported as a view XML
tag. I'm not sure what you mean by adding attachment names and icons to the
view, but nothing related to attachments is supported in view XML.
In Outlook 2007 they added a lot of new View stuff that wasn't there in
earlier versions of Outlook, but still not what you want.
news:eWBWFhxHKHA.4024@TK2MSFTNGP02.phx.gbl...
Ashish
What i want to do?
When select a folder in outlook addin, show attachment icon for all
mails(which dont have any attachment) under this folder.
By default outlook displays attachment icon for those mails which have
attachments. But here i want to do it for those mails which dont have
attachments.
When select a mail(which dont have attachment) in outlook addin show an
attachment in right pane for this mail(this attachment exist on local system
and display in right pane of selected mail), this attachment should not add
to exchange server for this mail but we can show attachment in outlook only.
Is that possible? is there any way to do it
news:uoEc1E0HKHA.6068@TK2MSFTNGP03.phx.gbl...
> the view, but nothing related to attachments is supported in view XML.
K
No, what you want is not possible. Instead of beating your head trying to do
something that can't be done why not re-architect your design?
news:OWFauB%23HKHA.1684@TK2MSFTNGP04.phx.gbl...
> What i want to do?
> attachments.
> system and display in right pane of selected mail), this attachment
> should not add to exchange server for this mail but we can show attachment
> in outlook only.
Ashish
Thank you very much for clearing this doubt.
news:%23nHzAPAIKHA.4376@TK2MSFTNGP03.phx.gbl...
> do something that can't be done why not re-architect your design?
> > What i want to do?
> > attachments.
T Outlook 2010 Cannot edit Calendar entries in OL 2010. Using Outlook 1
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
D Edit Subject (Multiple Accounts) Outlook VBA and Custom Forms 5
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
P "Edit Message" feature removed in Outlook 2016 for Mac Outlook VBA and Custom Forms 0
snissen Where is "Edit Message" in Outlook 2016? Using Outlook 2
P People/Contact Record gets deleted when I edit it? Using Outlook 3
C Edit/Create Pen Not Working Outlook 2013 Using Outlook 1
X Bulk edit Contact forms Using Outlook 2
A Contact address disappears when opened to edit Using Outlook 5
J Can invitee edit details? Using Outlook 1
R Edit Subject Line of Meeting Invitation? Using Outlook 1
G Outlook 2013: Cannot Edit default Holiday Calendar Using Outlook 2
V Custom form won't open for edit Outlook VBA and Custom Forms 3
M Bulk Edit contact notes BCM (Business Contact Manager) 1
P Edit Subject for every sent message Outlook VBA and Custom Forms 3
M Any way to edit the message field on a 2010 Outlook Form? Using Outlook 3
S OL 2010 shortcut to edit received mail Using Outlook 3
A Cannot edit or open existing contact nor add new ones. BCM (Business Contact Manager) 1
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
M Outlook 2003: Cannot edit default Contact Form Using Outlook 11
S how can i edit email address/es from the from field Using Outlook 5
M How to edit a monthly calendar to remove the cover page Using Outlook 1
S How do I edit an attachment in an invite without notifying the attendees? Using Outlook 2
B Notice to user of appt. set by person with permission to edit (Outlook 2003) Using Outlook 7
H Edit email message Using Outlook 7
F Text Format Change - Bulk Edit Contact Notes Using Outlook 2
T Unable to edit Distribution Group membership via Outlook (works via ECP). Exchange Server Administration 7
D How do I edit a macro in Outlook? Outlook VBA and Custom Forms 1
E Currency Edit Control on custom Taskpanes Outlook VBA and Custom Forms 1
S Correct way to Identify is Mail is opened in Edit Mode Outlook VBA and Custom Forms 1
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
williamlambton Reinstate "Open" button on mail item right-click context menu. Outlook Wishlist 2
T Forwarded long email moves text to the right Using Outlook 1
