UserProperty of mail object problem while dealing with custom fold
  • Thread starter Problem with UserProperty of mail object
  • Start date
P
hi,
The error i come across while dealing with saving the
UserProperties of mails being directed to custom folders is 'The operation
cannot be performed because the message has been changed.'
The following is my code.
// this is called in 'ThisAddIn_Startup' method whenver a new mail is received
this.Application.NewMailEx += new
Microsoft.Office.Interop.Outlook.ApplicationEvents_11_NewMailExEventHandler(Application_NewMailEx);
// the definition for 'Application_NewMailEx' is as follows
void Application_NewMailEx(string EntryIDCollection) //autolinking
if (strAutoLink == "ON")
string[] entries = EntryIDCollection.Split(',');
for (int c = 0; c < entries.Length; c++)
objMailItems =
(Outlook.MailItem)objNamesSpace.GetItemFromID(entries.GetValue(c).ToString(),
objInbox.StoreID);
threadMail = new Thread(new ThreadStart(fnNewMailRecv));
threadMail.Start();
//the definition for 'fnNewMailRecv()' is as follows
public void fnNewMailRecv()
try
Outlook.MailItem newMail = objMailItems;
currentMail = objMailItems;
GenModClass objGenMod = new GenModClass();
bool toLink = ThisAddIn.bLinkInCRM;
string strSenderName = newMail.SenderName.ToString();
string strUserName = objUser.userName.ToUpper();
Outlook.NameSpace objOUTLOOKNS =
this.Application.GetNamespace("MAPI");
Outlook.UserProperty objCRMGoldRecid;
Outlook.UserProperty objLinkedToContact;
Outlook.UserProperty objLinkedToCompany;
Outlook.UserProperty objLinkCheckBox;
newMail.Save();
objCRMGoldRecid = newMail.UserProperties.Add("RECID",
Outlook.OlUserPropertyType.olText, true, System.Reflection.Missing.Value);
objLinkedToContact = newMail.UserProperties.Add("Linked
to Contact", Outlook.OlUserPropertyType.olText, true,
objLinkedToCompany = newMail.UserProperties.Add("Linked
to Company", Outlook.OlUserPropertyType.olText, true,
objLinkCheckBox = newMail.UserProperties.Add("Is
Linked", Outlook.OlUserPropertyType.olYesNo, true,
string strSenderEmailAddress = "";
if (newMail.SenderEmailAddress != null)
newMail.SenderEmailAddress.ToString();
string strFrom = strSenderEmailAddress == null ? ""
: strSenderEmailAddress;
string strTo = newMail.To == null ? "" : newMail.To;
string strCC = newMail.CC == null ? "" : newMail.CC;
string strBcc = newMail.BCC == null ? "" :
newMail.BCC;
string strSubject = newMail.Subject == null ? "" :
newMail.Subject;
if (strSubject.Length > 80)
strSubject = strSubject.Substring(0,
80).ToString();
string strMsgBody = newMail.HTMLBody == null ? "" :
newMail.HTMLBody;
string strImp = newMail.Importance.ToString();
string strAccountNo=string.Empty;
//gnerating some id
string strMailBoxRecID =
objGenMod.GenerateRecId().ToString(); string
strHasAttachment = (newMail.Attachments.Count > 0) ? "Yes" : "No";
//to get a user's account no from my database
string sqlQuery = "SELECT
dbo.Fun_Email_getLinkAccountNo('" + strSenderEmailAddress + "') AS
ACCOUNTNO";
DataSet ds= new DataSet();
try
// calling the webservice
ds =
crmService.executeCustomQuery(ThisAddIn.SessionID, sqlQuery,
objUser.userName, ThisAddIn.IPAddress);
catch (Exception Ex)
MessageBox.Show(Ex.Message);
fnWriteErrorLog(Ex);
return;
if (ds.Tables.Count > 0)
if (ds.Tables[0].Rows.Count > 0)
strAccountNo =
ds.Tables[0].Rows[0]["ACCOUNTNO"].ToString();
else
strAccountNo = "";
if (strAccountNo == "") //email address not found
in db
objCRMGoldRecid.Value = "UNLINKED";
objLinkedToContact.Value = "";
objLinkedToCompany.Value = "";
objLinkCheckBox.Value = false;
if (strAccountNo != "")
StringBuilder strRFC822 = new StringBuilder();
strRFC822.Append(" ");
string strMessageID = newMail.EntryID;
strRFC822.Append(newMail.ReceivedTime.ToString("ddd, dd MMM yyyy
hh:mm:ss")); //0
strRFC822.Append("^ ");
strRFC822.Append(strFrom); //1
strRFC822.Append(strSubject); //2
strRFC822.Append(strTo); //3
strRFC822.Append(strCC);//4
strRFC822.Append(strHasAttachment);//5
strRFC822.Append("^ <");
strRFC822.Append(strMessageID);//6
strRFC822.Append(">");
strRFC822.Append(strMsgBody);//7
string oldFileName = string.Empty;
string extn = string.Empty;
string FileName = string.Empty;
string emailattachments = "";
strRFC822.Append(emailattachments);//8
strRFC822.Append(newMail.BodyFormat.ToString());//9
strSubject = strSubject.Substring(0, 80);
string strRecdOnDate =
newMail.ReceivedTime.ToString();
sqlQuery = "SELECT companyid FROM
tblcompanycontact WHERE accountno='" + strAccountNo + "'";
try
//calling webservice
ds =
objUser.userName.ToUpper(), ThisAddIn.IPAddress);
return;
//create new database record
crmEZService.EmailMessage objEmailMessage =
new CRMGoldOutlook.crmEZService.EmailMessage();
objEmailMessage.recID = "";
objEmailMessage.Flags = "";
objEmailMessage.lopRecId = "";
objEmailMessage.Folder = strFolderType;
objEmailMessage.Folder2 = "";
objEmailMessage.MessageID = strMessageID;
objEmailMessage.Attachment = strHasAttachment;
objEmailMessage.userId =
objEmailMessage.MailSize =
newMail.Size.ToString();
objEmailMessage.MailDate =
DateTime.Parse(strRecdOnDate).ToString("yyyy-MM-dd");
objEmailMessage.MailTime =
newMail.ReceivedTime.ToString("HH:mm");
objEmailMessage.MailRef = strSubject;
objEmailMessage.RFC822 = strRFC822.ToString();
objEmailMessage.contactID = strAccountNo;
objEmailMessage.linkRecId = "";
string MAILBOXRECID = string.Empty;
try
//a new id is generated and returned by webservice
MAILBOXRECID =
crmService.createNewCRMObject(ThisAddIn.SessionID, objEmailMessage,
ThisAddIn.objUser.userName.ToUpper(), ThisAddIn.IPAddress);
return;
sqlQuery = "SELECT ISNULL(company,'')as
Company, ISNULL(contact,'') as Contact FROM contact1 WHERE accountno='" +
strAccountNo + "'";
try
ds =
return;
// From here onwards, if there are no 'Rules and Alerts' specifed to direct
the received mails to custom folder, the values are assigned
// perfectly to UserProperties. But when
there are rules mentioned to move the received mail to a user created
'Personal folder', then
// the following error is thrown 'The operation cannot be performed
because the message has been changed.' and the values are not fed
// into the user properties.
if (objCRMGoldRecid != null)
MAILBOXRECID;
ds.Tables[0].Rows[0]["Contact"].ToString();
ds.Tables[0].Rows[0]["Company"].ToString();
objLinkCheckBox.Value = true;
newMail.Save();
Thanks in advance.
K
Ken Slovak - [MVP - Outlook]
You're using a new thread to access the Outlook object model, which is
really, really bad. That is not supported and will cause Outlook to crash or
hang in most cases. Get rid of that and localize where the problem is coming
in your code. You need to show only the relevant code, no one is going to
want to wade through all that code to try to find problems.
"Problem with UserProperty of mail object"
<ProblemwithUserPropertyofmailobject> wrote in
message news:1228956D-3C18-430B-BA46-1C9B0BF496BB@microsoft.com...
> hi,
> received
> objMailItems =
> objInbox.StoreID);
> threadMail.Start();
> try
> newMail.Save();
> newMail.To;
> newMail.CC;
> newMail.BCC;
> newMail.Subject;
> 80).ToString();
> newMail.HTMLBody;
> //gnerating some id
> ACCOUNTNO";
> try
> ds =
> return;
> strAccountNo =
> else
> strAccountNo = "";
> found
> in db
> StringBuilder();
> hh:mm:ss")); //0
> 80);
> try
> ds =
> return;
> strHasAttachment;
> try
> MAILBOXRECID =
> return;
> strAccountNo + "'";
> try
> ds =
> return;
> direct
> when
> MAILBOXRECID;
> newMail.Save();
> Thanks in advance.
P
Re: UserProperty of mail object problem while dealing with custom
hi Ken,
Using a new thread to access the Outlook object model was the main
problem for me to get the error 'The operation cannot be performed because
the message has been changed.' I removed that new thread and called
'fnNewMailRecv()' directly and it worked great without that error.
A ton of thanks to you for your wonderful support.
Thanks & Regards,
Varma.
> > hi,
> > received
> > objMailItems =
> > objInbox.StoreID);
> > threadMail.Start();
> > try
> > newMail.Save();
> > newMail.To;
> > newMail.CC;
> > newMail.BCC;
> > newMail.Subject;
> > 80).ToString();
> > newMail.HTMLBody;
> > //gnerating some id
> > ACCOUNTNO";
> > try
> > ds =
> > return;
> > strAccountNo =
> > else
> > strAccountNo = "";
> > found
> > in db
> > StringBuilder();
> > hh:mm:ss")); //0
> > 80);
> > try
> > ds =
> > return;
> > strHasAttachment;
> > try
> > MAILBOXRECID =
> > return;
> > strAccountNo + "'";
> > try
> > ds =
> > return;
> > direct
> > when
M Using .Restrict with a UserProperty in an Exchange folder Outlook VBA and Custom Forms 4
S Userproperty question Outlook VBA and Custom Forms 1
L Retrieving the DisplayFormat for a UserProperty using VB Outlook VBA and Custom Forms 3
R Outlook 2007: Userproperty missing after sending Outlook VBA and Custom Forms 3
R Sent emails show iCloud mail account not the alias Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
MrMayor SENT mail not reloading to top?? Using Outlook 4
ThinkToday Calculate reply time of outlook mail Using Outlook 1
B Outlook 2010 Opening Mail Attachment Using Outlook 2
D Mail in Sent Items Gone Using Outlook 12
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
S Outlook not receiving mail Using Outlook 1
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
W Receiving mail for account that has been deleted Using Outlook 2
O How to prevent CC from showing when creating a new mail? Using Outlook 1
I Junk Mail and PersonMetadata Using Outlook 2
T 3 months of archived e-mail is missing Using Outlook 1
