Eliminate need for "Enable Macro" selection
C
cte67
I created a macro. At first it did not work after restarting Outlook 2007.
Under Macro Security, I set "Warnings for all Macros". Then the macro
worked after restarting.
However, when I run the macro for the first time, I get the message,
"Microsoft Office has identified a potential security concern ...." I choose
the "Enable Macros" button.
I did run SelfCert.exe ... gave it the name Macros. No difference ... still
asks about enabling macros after I restart Outlook.
K
Ken Slovak - [MVP - Outlook]
If you have security set to always prompt that's what you get even with a
signed VBA project.
After creating the certificate did you sign your VBA project with it? You do
that from the Tools, Digital Signature menu entry in the VBA project's
menus. Then you set your security to High, exit and restart Outlook and you
shouldn't get that prompt.
"cte67" <cte67> wrote in message
news:95394241-1E5B-4D44-999C-7259ABDE5238@microsoft.com...
> choose
> still
C
cte67
Thanks for the info! Where do I set security to High?
> signed VBA project.
K
Tools, Macro, Security.
news:8005A141-EC95-453C-A798-5E41F72B4A65@microsoft.com...
C
cte67
I should have been clearer. I had looked there ... did not see any option
for setting security to high. I'm running Outlook 2007.
K
Did you look in the Tools menu of the Outlook Explorer (folder view)? It's
right there. Tools, Macro, Security. You can get to the same spot by using
the Trust Center and going to the Macro Security tab.
news:35D3075C-3F1F-4190-81BD-8327CEA1F327@microsoft.com...
C
cte67
I had checked there. Don't see any option for setting security to High.
K
In 2007 that option is called "Warnings for signed macros; all unsigned
macros are disabled". Unfortunately it doesn't disable the warnings. The way
to do that is to have no security check which is dangerous.
news:236689B2-B32C-4840-8217-EA04AF79E725@microsoft.com...
> > It's
> > using
N Eliminate the +1 before all numbers Using Outlook 1
R how do I eliminate allow access dialog box using VBAproject in Out Outlook VBA and Custom Forms 1
K How do I eliminate the "Enable Macro" selection? Outlook VBA and Custom Forms 16
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
Horsepower Need iCloud mail only Using Outlook 1
O Don't need any add-ins at all? Using Outlook 2
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
L Accidentally merged a calendar with .ics, need to undo! Using Outlook 1
D Need Genuine Office or Outlook 2007 Using Outlook 3
G how to cancel a recurring meeting but not the organizer but all attendees need to know. Using Outlook 1
N Need a case sensitive rule Outlook VBA and Custom Forms 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
Miquela I need to make a calendar to share here at work with 40 other people Using Outlook 1
S Need CC: to show the original To: recip[ients Using Outlook 4
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
mikecox Desperat; need hands on support Using Outlook 1
Glyn Do I Need Outlook.com Using Outlook 1
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
