How to provide custom functionality on click of "New"?
madhavi
I am developing an outlook addin in c#
I need to take some custom action, when user clicks “New” button or presses “CTRL + N” instead of displaying a new mail message. As there is no onclcik event for commandbarpopup, I tried to add onAction property as follows. But when I run the addin in debug mode, I am getting exception as “Member Not Found …..”
How can I provide my own functionality on click of New (I am able to achieve this, if user clicks on any item in the dropdown list of new as they are commandbuttons and they have onclicj)
Office.CommandBarPopup cbc = (Office.CommandBarPopup)
this.Application.ActiveExplorer().CommandBars.FindControl
(Office.MsoControlType.msoControlPopup, 30037, missing, missing);
cbc.OnAction = "newMenu_Click";
public void newMenu_Click(Microsoft.Office.Core.CommandBarPopup Ctrl, ref bool CancelDefault)
MessageBox.Show("new button clicked............");
Any help is very much appreciated
K
Ken Slovak - [MVP - Outlook]
There are no events for that, as you can see in the Object Browser. You can
handle clicks on the buttons but that's about it. What are you trying to do?
You can add your own buttons to the popup and you can repurpose existing
buttons, but you can't do what you want.
"madhavi" <madhavi.40cg3a@invalid> wrote in message
news:madhavi.40cg3a@invalid...
> Hi,
> I need to take some custom action, when user clicks "New" button or
> presses "CTRL + N" instead of displaying a new mail message. As there is
> exception as "Member Not Found ..."
> missing);
> > madhavi
T You must Provide a value for this property on powershell cmdlet Exchange Server Administration 3
M Index / Search outlook data to provide search assistance in Ol 2003/ 2 Outlook VBA and Custom Forms 1
M How to provide instant search like feature in outlook 2003? Outlook VBA and Custom Forms 1
E Custom formula for columns Using Outlook 3
