Program "Click on Ribbon Button" Using VBA
H
hlock
I don't know if anyone can help me, but I thought I would ask. In Outlook
2007, we have a 3rd party add-in that imports an email to a document
repository. The "Save to Vignette IDM" button resides on the command bar in
explorer and in the Add-Ins menu on the ribbon. Thanks to Sue Moshier, we
are able to "click" on the button on the command bar in explorer. However,
the code only runs for the highlighted email in explorer. The problem is
when we have multiple emails up and want to import an open email that is not
selected in explorer. The code runs, but it imports the selected email in
explorer, not the active email.
I need to be able to "click" on the button on the ribbon using vba
(basically execute the event with vba) and execute the command for the open
email (inspector). I don't want to modify the code. Unfortunately, I do not
have access to the source. Any ideas?
Sub RunIt()
Dim cb As Office.CommandBar
Dim cbb As Office.CommandBarButton
Dim ctrl As Office.CommandBarControl
Dim exp As Outlook.Explorer
Set exp = Application.ActiveExplorer
Set cb = exp.CommandBars("Standard")
For Each ctrl In cb.Controls
If ctrl.Caption = "Save to Vignette IDM" Then
Set cbb = ctrl
cbb.Execute
Exit For
Set cb = Nothing
Set cbb = Nothing
Set ctrl = Nothing
Set exp = Nothing
K
Ken Slovak - [MVP - Outlook]
If the code only works on a selected item in an Explorer then that won't
help you at all for an Inspector. The button code would need to work on
ActiveInspector, not on Selection(1).
I don't see any way of doing what you want unless you write your own code to
mirror the functions of the button, or you get the addin author to change
things for you.
"hlock" <hlock> wrote in message
news:1FF17730-FD07-44C5-9C39-907A207E9544@microsoft.com...
> in
> However,
> not
> open
> not
> Sub RunIt()
> Set cbb = ctrl
> cbb.Execute
> Exit For
> End If
> Next
> Set cb = Nothing
> Set cbb = Nothing
> Set ctrl = Nothing
> Set exp = Nothing
> End Sub
> Thanks.
S Email Generated from another program and then edited sends original email. Using Outlook 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
R SearchPublicFolders program Outlook VBA and Custom Forms 1
Diane Poremsky To Change the Default E-mail Program in Windows Using Outlook 0
I There is no email program associated to perform requested action Using Outlook 0
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
J My Outlook program has stopped receiving. I can still send Using Outlook 1
C New version of MFCMAPI program Using Outlook 0
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
A outlook 2007 - there is no email program associated ... Using Outlook 3
F Default Program for Opening .pst Files ? Using Outlook 6
A Outlook-Program Not Closing Properly Using Outlook 10
B How to remove an old program from the Tools dropdown? Using Outlook 7
D How to set permissions to allow external program to send an email? Using Outlook 0
T getting an error This file does not have a program associated with it for performing this action. C Using Outlook 7
N The add-in "C:\program files\google\google desktop search\googledesktopO..." could not be installed Using Outlook 32
R Access Program Only Looping Part Way Through Outlook Inbox Outlook VBA and Custom Forms 2
M Allow or Deny when a Program tries to send an email Outlook VBA and Custom Forms 1
R how to (re)set the default data file for Outlook in a VB program Outlook VBA and Custom Forms 2
J Program won't end in Win7 Outlook VBA and Custom Forms 1
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
S Email Organizer Program Outlook VBA and Custom Forms 2
G GAL program acces in outlook 2007 Outlook VBA and Custom Forms 2
H Program email save as text file Outlook VBA and Custom Forms 5
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
N How to attach a file with MS Outlook, from a program? Outlook VBA and Custom Forms 3
Q why this program doesn't work if Outlook is not manually launched? Outlook VBA and Custom Forms 4
V how to switchoff program access message in outlook 2003 Outlook VBA and Custom Forms 1
V "A program has attachment filename open" Message returns Outlook VBA and Custom Forms 4
J Program Compatibility Issue - Outlook 2003 BCM BCM (Business Contact Manager) 4
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
F Jump to Inbox folder when click on Favorite Using Outlook 0
I BCM Opportunity: click on "new op" opens a "new tasks" BCM (Business Contact Manager) 0
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
