Outlook Appointment recurrence setting
JP Ronse
Hi All,
I am working on an automation project to send recurrent meeting requests
from an Excel file on.
Everything works fine for weekly, monthly and monthNth recurrent meetings.
Also daily recurrent meetings are OK but the thing I don't see is how to
specify that 'every weekday' option has to be used. I'm usiing Office/Oulook
2003.
Part of my code:
Select Case golRecurrenceInfo_Occurence
Case olRecursDaily
olRecurrencePattern.RecurrenceType = olRecursDaily
olRecurrencePattern.Interval =
golRecurrenceInfo.Interval
Case olRecursWeekly
olRecurrencePattern.RecurrenceType = olRecursWeekly
golRecurrenceInfo.Interval is an intenal variable containing the recurrency
info. I would be grateful for any help.
Wkr,
JP
JP Ronse
Hi Michael,
Thanks for your help. You are right. Meanwhile I was able to figure out that
I had to use 62 as DayOfWeekMask to point to every weekday (Mon to Fri).
Wkr,
JP
JP Ronse
Hi Dimitry,
Thanks for your help. Indeed it is 62. I was able to figure it out with some
other code I have already in use.
If I had a look to all constants and not only to olSunday & olMonday, I
would have seen that Sun =1, Mon =2... Sat =64 and not the usual values 1 to
7.
Wkr,
JP
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
F Outlook 2010 Search Appointment Notes Using Outlook 0
Tech Checkers Make Outlook add Contact Card Address in Location Field based on Appointment Subject Name. Using Outlook 2
K Importing appointment body from excel in outlook 2010 Using Outlook 1
M Outlook appointment in asp.classic Using Outlook 2
L Showing @live account in outlook 2013 calendar as private appointment Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
J Outlook 2010: can't forward appointment on custom form Using Outlook 1
Rijotech Outlook 2013 Appointment list custom positions? Using Outlook 2
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
R Static Resources in Custom Outlook Appointment Form Using Outlook 2
L Outlook 2007 Code for Note Fields of Appointment Using Outlook 102
M Outlook Appointment Item exceeds beyond the date range Using Outlook 2
S Calendar deletes appointment after entry from both Outlook and Icloud calander Using Outlook 1
M Outlook Appointment item does not show the item outside the date range Using Outlook 2
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
C Outlook Appointment issue when synchronized with iCloud 2 Using Outlook 8
M "New Appointment from Contact" command missing from Outlook 2003 Using Outlook 1
B Outlook Calendar Appointment Problem Using Outlook 1
O Rescheduling appointment on Outlook 2010 for Windows creates duplicate entry Using Outlook 2
T Outlook makes every appointment recurring and set to the current date/time Using Outlook 2
P Create appointment to custom (shared) outlook calendar Outlook VBA and Custom Forms 3
S Custom Form overwriting the default appointment form in outlook 20 Outlook VBA and Custom Forms 1
Q How outlook Store Appointment Outlook VBA and Custom Forms 1
