Call add-in method from macro?
Duncan McNiven
I am using Delphi (2009) to write my first add-in for Outlook (2007). I want to add a custom method to my add-in's class and call it from an Outlook macro, but I can't get it working.
My method in my Delphi class is public. It looks like this:
procedure MyMethod(const Index : integer); safecall;
I tried to call it from Outlook like this:
Sub Test_02()
Application.COMAddIns.Item("<My Add In>").Object.MyMethod (3)
I get:
Run-time error '91':
Object variable or With block variable not set
I then tried:
Sub Test_01()
Dim MyAddIn As Office.COMAddIn
Set MyAddIn = Application.COMAddIns.Item("<My Add In>")
If Not (MyAddIn Is Nothing) Then
If MyAddIn.Connect = True Then
Dim MyObject As Object
Set MyObject = MyAddIn.Object
If Not (MyObject Is Nothing) Then
MyObject.MyMethod (3)
This fails because MyObject is Nothing, so the call to MyObject.MyMethod doesn't happen.
My next attempt was:
Sub Test_03()
Set MyObject = CreateObject("<My Add In>")
MyObject.DoNewMail (Null)
The DoNewMail method is the handler for Outlooks OnNewMail event, and is called correctly when new mail is received. I guess CreateObject would create a new object rather than use the one already instantiated in my Add-In, which is not what I want, but I was trying everything at this stage. Anyway, this attempt failed with:
Run-time error '438':
Object doesn't support this property or method
So where am I going wrong?
Duncan McNiven
Re: Call add-in method from macro? SOLVED
After being stuck on this for days I hit on a solution.
In my OnConnection event in the Delphi code I put something like:
var
SelfDisp : OleVariant;
begin
SelfDisp := Self as IMyClassDisp;
OleVariant(AddInInst).Object := SelfDisp;
(IMyClassDisp is a descendant of IDispatch).
Then the IMyClassDisp methods included in the type library can be called from a macro using the same syntax I had tried earlier.
Just thought I would post this note in case anyone else finds this thread whilst stuck on the same problem.
T exception when I call ActiveDocument.Range(0,0).Editors.Add(-1) Outlook VBA and Custom Forms 2
F Outlook 2016 call to Stop Timer Event Outlook VBA and Custom Forms 4
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
M How to call custom email form when sender = x Using Outlook 3
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
C OL Sub through or by Excel Macro Call Outlook VBA and Custom Forms 1
S How to call a procedure from a custom command bar in Outlook 2007 Outlook VBA and Custom Forms 1
R Phone Call Start Date - Phone Log BCM (Business Contact Manager) 1
B Good Call Log Concept? Outlook VBA and Custom Forms 5
M Phone Log Reminder to call back BCM (Business Contact Manager) 1
R Help, Outlook2003 won't quit after call OnDisconnection? Outlook VBA and Custom Forms 3
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
C How do you call a exe and interact with the output interactively Outlook VBA and Custom Forms 2
C-S-R Manage Add-ins (Remove Wunderlist) Using Outlook 3
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
B Task Filter Not Working When I add too many criteria Using Outlook 0
