How to move Hotmail folders to Outlook 2007?
Z
ZGVzZXJ0cmF0MTkyOA
I'm using both Windows Live Hotmail and Outlook 2007. I have personal folders
on my Hotmail web based email that I want to import into Outlook 2007. I
cannot locate a way to save the Hotmail personal folders to import into my
personal folders in Outlook 2007. When I installed Outlook 2007 and
syncronized the mail, the first four of my 32 personal folders copied the
contents to Outlook 2007, but 28 personal folders on Outlook 2007 remain
empty. Any help would be appreciated as I'm faced with re-sending each email
to myself and then placing in the Outlook folders.
XP, Office 2007, Using Windows Hotmail Live
Roady [MVP]
Have you the latest Outlook Connector installed already?
All mail should be available to you in Outlook already then. You can then
just drag & drop to move your emails to someplace else.
If somehow not all the folders show up in Outlook, remove the Live Hotmail
account from Outlook, restart Outlook and then add the account again.
http://www.howto-outlook.com/
http://www.msoutlook.info/
Z
ZGVzZXJ0cmF0MTkyOA
Thanks Roady, but it is not an issue with the folders not showing in Outlook
2007, but rather that they don't contain the emails that are in the hotmail
folders. I have the most current Outlook Connector version, but cannot drag
and drop folders, nor can I copy or export them.
Roady [MVP]
> hotmail
> folders.
The same solution applies ;-)
> cannot drag and drop folders, nor can I copy or export them.
You'd have to move the individual items instead. Use CTRL+A to select all
items in a fold at once.
<snipped>
R3V5
"senRoady - I hope my question is related (if not, I'd be happy to start a
new thread). I have Outlook 2007 on Vista Home and a Hotmail account. Over
the years (with Outlook 2003 prior to 2007) I have sent email either from
Outlook or from the Hotmail webmail facility. Mail sent from Outlook is
filed both in "sent items" in my personal folders and also on the Hotmail
server; mail sent from the webmail interface is just stored on the server.
I want to synchronise the "sent items" folders to finish up with a single
definitive list in my Personal Folders, then I'll empty "sent items" folder
on the server. I've got over 1,000 sent items on the server, roughly half of
which I wrote and sent from Outlook (and which are therefore already filed in
my Personal Folders). Ideally, I want to do a single 'select' of all sent
items on the server and then do a copy or move to Personal Folders, BUT
WITHOUT DUPLICATING ITEMS. Is this possible?
> > hotmail
> > folders.
> <snip>
bobw.family
Outlook 2007
OK, I've seen an area dealing with -How to move Hotmail folders to Outlook 2007?- Its about 4 feet long and , to me, the answer is not obvious. Please direct me to the steps I need to move my Hotmail emails to my Outlook 2007, on Vista.
Bob
Forum Admin
You want to move your mail from Hotmail online to Outlook? You need to either use the hotmail connector or create a POP3 account to your hotmail account. If all of the mail is in the Hotmail inbox, POP3 works fine. If you have mail sorted into different folders online, you'll want to use the Outlook Hotmail Connector.
See Online Services for POP3 config - links to the outlook hotmail connector are in the right sidebar of that page, near the top (scroll up that page).
J Dopey move - deleted profile Using Outlook 1
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
N Move emails of same conversation to same subfolder Using Outlook 6
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
F "Move to" O365 feature to Outlook client via VBA Outlook VBA and Custom Forms 4
B Macro to manually move selected emails to network folder Outlook VBA and Custom Forms 1
L Making rule to move email to folder from one O365 domain Using Outlook 1
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
