How do I move a message to a folder after forwarding ?
Albert
I am forwarding a message then after sending want to move it to the TRUVO
folder. Can someone help, what have I done wrong ??
thanks .. Alb
Sub ForwardHome()
Rem forward a highlighted email to the email address nominated
Rem to work correctly the Function GetCurrentItem() must also be included
Dim ObjMail As Outlook.MailItem
Set objItem = GetCurrentItem()
Set ObjMail = objItem.Forward
ObjMail.To = systems@destination.aa
ObjMail.Send
Set objItem = Nothing
Set ObjMail = Nothing
Rem this first part works okay !
Rem now next bit should move highlighted email to nominated folder
"Personal folders/TRUVO" after being sent
Set oInboxItems = bjNS.GetDefaultFolder(olFolder"Personal folders").Items
Set olns = Item.Application.GetNamespace("MAPI")
Set objTargetFolder = Outlook.Session.PickFolder
Set objCurItem = oInboxItems.Item(1)
Set objCurItem = objCurItem.Move(objTRUVO)
Set objApp = Application
Case "Explorer"
Case "Inspector"
Case Else
End Function
Sue Mosher [MVP]
You want to move the original message? I don't understand why you're not
simply using objItem.Move objTargetFolder.
Sue Mosher
"Albert" <help-me@skynet.be> wrote in message
news:%23J$w0mcdKHA.3300@TK2MSFTNGP02.phx.gbl...
> thanks .. Alb
> Sub ForwardHome()
> ObjMail.Send
> End Sub
> Function GetCurrentItem() As Object
> Dim objApp As Outlook.Application
> On Error Resume Next
> Select Case TypeName(objApp.ActiveWindow)
> Case "Explorer"
> Set GetCurrentItem = objApp.ActiveExplorer.Selection.Item(1)
> Case "Inspector"
> Set GetCurrentItem = objApp.ActiveInspector.CurrentItem
> Case Else
> End Select
> End Function
Albert
Thanks, but I tried that. I had the following
Set objTargetFolder = "Personal Folders/TEST"
ObjItem.Move objTargetFolder
but it wouldn't work, so I searched www for an alternative and found the
code I previously posted (which also didn't work) together with some
explanation that seemed to say that I had to use a MAPI folder. Sorry but
I'm a bit new at this !
Alb.
"Sue Mosher [MVP]" <suemvp@gmail.com> wrote in message
news:%23Ciau$ndKHA.5228@TK2MSFTNGP06.phx.gbl...
> > Sue Mosher
>> thanks .. Alb
>> Sub ForwardHome()
> > ObjMail.Send
>> End Sub
> > Case "Explorer"
> > Case "Inspector"
> > Case Else
> > End Select
> > End Function
Sue Mosher [MVP]
"Personal Folders/TEST" is a string. You can't wish it into a Folder or
MAPIFolder object. However, your code already has a statement that returns a
valid objFolder object:
Set objTargetFolder = Application.Session.PickFolder
Why not use that? Or are you trying to move the item always to the same
folder? If that's the case, you need to walk the folder hierarchy using the
Folders collections or use a function that does that for you. For examples,
see:
http://www.outlookcode.com/codedetail.aspx?id=628 - uses a folder path
string
http://www.outlookcode.com/codedetail.aspx?id=492 - searches for a folder by
name
Sue Mosher
news:ef7d8k0dKHA.5608@TK2MSFTNGP05.phx.gbl...
> Alb.
>> > > Sue Mosher
>>> thanks .. Alb
>>> Sub ForwardHome()
> >> included
> >> ObjMail.Send
> >> folders").Items
>>> End Sub
> >> Case "Explorer"
> >> Case "Inspector"
> >> Case Else
> >> End Select
> >> End Function
Albert
Yes, I am trying to move the item always to the same folder. I can get the
PickFolder option to work, but that doesn't fit my situation, hence my
previous try to use the MAPI option which I still don't really understand.
However, thanks for the guidance, I will study the two examples. Obviously
this is not for beginners like me !
Alb
news:OwcYoq0dKHA.4880@TK2MSFTNGP05.phx.gbl...
> a valid objFolder object:
> the Folders collections or use a function that does that for you. For
> examples, see:
> string
> by name
> > Sue Mosher
>> Alb.
>>> > >> Sue Mosher
> >>>TRUVO
>>>> thanks .. Alb
>>>> Sub ForwardHome()
> >>> included
> >>> ObjMail.Send
> >>> folders").Items
>>>> End Sub
> >>> Case "Explorer"
> >>> Case "Inspector"
> >>> Case Else
> >>> End Select
> >>> End Function
Albert
Re: book with basics of using vba ?
Dear Sue
I see that you have some books for sale on how to use vba. I am sure I would
benefit .. are the books posted to me or electronic download ? Also, can you
suggest a good basic book that would point me in the right direction using
vba ? Is the vba used in Outlook2003 the same as Outlook 2007 and other
Office applications generally ?
thanks .. Alb
> examples, see:
> string
> by name
> > Sue Mosher
>> Alb.
>>> > >> Sue Mosher
> >>>TRUVO
>>>> thanks .. Alb
>>>> Sub ForwardHome()
> >>> included
> >>> ObjMail.Send
> >>> folders").Items
>>>> End Sub
> >>> Case "Explorer"
> >>> Case "Inspector"
> >>> Case Else
> >>> End Select
> >>> End Function
Sue Mosher [MVP]
My latest book is available in both hard-copy and Kindle versions, plus an
electronic version (that looks quite costly) from
http://www.sciencedirect.com/science/book/9781555583460. You can also search
for particular topics in it at Google Books.
VBA is the same in every Office application. My books cover the VBA basics
that are most useful for Outlook programming. If you need a broader
introduction, I like Paul McFedries' Absolute Beginner's Guide to VBA.
Sue Mosher
"Albert" <albert@gmail.com> wrote in message
news:u6PLkB$dKHA.5568@TK2MSFTNGP02.phx.gbl...
> would benefit .. are the books posted to me or electronic download ? Also,
> can you suggest a good basic book that would point me in the right
> direction using vba ? Is the vba used in Outlook2003 the same as Outlook
> 2007 and other Office applications generally ?
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
H move to folder rule corrupts message Using Outlook 3
T What code to use to move the custom field values to message body when sending e-mail ? Outlook VBA and Custom Forms 8
M Error message: "Cannot move the items..." Using Outlook 2
M Outlook 2010 IMAP account message move behavior Using Outlook 15
mikolajek Outlook 2013 IMAP actions (message move / delete etc.) significantly delayed Using Outlook 0
D Error message - Cannot move the items.... Using Outlook 1
J Move message skips messages when looping through mailbox Outlook VBA and Custom Forms 2
A How to catch Message Move Event. Outlook VBA and Custom Forms 10
J Dopey move - deleted profile Using Outlook 1
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
N Move emails of same conversation to same subfolder Using Outlook 6
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
