move folders in outlook using vba
P
pete the greek
hi all, im trying to work out how to move folders using vba, i have manged to
move emails to new folders but cant move folders
we use public folders at work and the one i have to drag and drop to is
buried some 10 levels down for the odd move this is no problem but at times i
could be doing 20-30
my problems are
how do you identify the current folder
and then how do you move it
this is what i have so far
myfolder being the one im trying to move
objfolder being the destination
im playing with this on my personal pc hence the required path is not so long
Sub foldermove()
Set myFolder = objNS.Folders.Item("personal folders").Folders.Item("ongoing
orders for uk").Folders.Item(1)
objfolder = objNS.Folders.Item("personal folders").Folders.Item("inbox")
myFolder.Move (objfolder)
Sue Mosher [MVP]
Application.ActiveExplorer.CurrentFolder
When in doubt, check the object browser: Press ALt+F11 to open the VBA
environment in Outlook, then press F2. Switch from <All Libraries> to
Outlook to browse all Outlook objects and their properties, methods, and
events. Select any object or member, then press F1 to see its Help topic. In
your case, a quick glance at the Folder or MAPIFolder object (depending on
your Outlook version, which you should always mention when posting in an
Outlook forum) would reveal a MoveTo method.
Sue Mosher
"pete the greek" <petethegreek> wrote in message
news:698A227B-1FBA-4CAD-9627-7E1E77FFA3AB@microsoft.com...
> to
> times i
> my problems are
> long
> Sub foldermove()
> Set objNS = Application.GetNamespace("MAPI")
> End Sub
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
O Missing guide "Move an Outlook Personal Folders .pst File" Using Outlook 4
Diane Poremsky Move Messages from File System into Outlook Folders Using Outlook 0
J Outlook Cannot Move Msgs to Folders (GMAIL IMAP) Using Outlook 1
B OUTLOOK 2013: How Do I Move Emails to Folders stored on my Hard Drive? Using Outlook 3
A How to move responded emaisl automatically to sub folders in Outlook 2007 Using Outlook 0
L Outlook 2010- Be able to move default Mail folders (Outbox, Draft, etc) Outlook Wishlist 1
Z Outlook 2007 move folders from one computer to another Using Outlook 1
D User cannot move email messages within Outlook Inbox folder and sub-folders. Using Outlook 0
S Outlook 2007 'Move To Folders missing from Inbox Using Outlook 5
Z How to move Hotmail folders to Outlook 2007? Using Outlook 6
Diane Poremsky Create Tasks from Email and move to different Task folders Using Outlook 0
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
A Move email items based on a list of email addresses Outlook VBA and Custom Forms 40
T Move calendar invites to new calendar Using Outlook 5
