MAcro - Need help in getting the recipients in to filed / cc field toput in an array
Shreekanth Murali
This is the macro to stop sending without a subject as well as to warn the user whn he sends to the distribution list that starts with "#"
However this code detects the email addresses in TO / CC as one single string.
For eg if i have
shreekanth Murali; #IN - distribution
then it detects "shreekanth murali; #in - distribution" and not warning the presence of a distributon list in TO field... Im a beginner please lemme know how can i do it
Private Sub Application_ItemSend(ByVal item As Object, Cancel As Boolean)
Dim strSubject As String
strSubject = item.Subject
If Len(Trim(strSubject)) = 0 Then
Prompt$ = "Subject is Empty. Are you sure you want to send the Mail?"
If MsgBox(Prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Check for Subject") = vbNo Then
Cancel = True
Dim a
Dim b
a = Mid(item.To, 1, 1)
If a = "#" Then
Prompt$ = "You are about to send an email to the distribution list " & item.To
If MsgBox(Prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Recipient is a distribution list") = vbNo Then
Cancel = True
CSS Stylesheet Sampler Script
http://www.eggheadcafe.com/tutorial...0-64466ee722bc/css-stylesheet-sampler-sc.aspx
Dmitry Streblechenko
Re: MAcro - Need help in getting the recipients in to filed / cc field to put in an array
Instead of using To/CC/BCC properties, loop through all the recipients in
the MailItem.Recipients collection.
Dmitry Streblechenko (MVP)
<Shreekanth Murali> wrote in message
news:20091218121113sirmurali@yahoo.com...
> string.
> For eg if i have
> Mail?"
> Cancel = True
> End If
> End If
> Dim a
> Dim b
> If a = "#" Then
> item.To
> Cancel = True
> End If
> End If
> End Sub
Shreekanth Murali
example please
Can you please guide me by giving me an example how to use this.... I am sorry i need to agree that i have just started to learn... i need your help please... we are gonna apply this for our people in my company...
Dmitry Streblechenko wrote:
Instead of using To/CC/BCC properties, loop through all the recipients inthe
18-Dec-09
Previous Posts In This Thread:
ASP.NET Digest Authentication Against Database
http://www.eggheadcafe.com/tutorial...af-8a9a5c91c0d6/aspnet-digest-authentica.aspx
Shreekanth Murali
item.recipients.Count
item.recipients.Count gives me number of recipients in the mail. How can i get the details of that . What should i user.
eg: I have three email address in to field and for testing purpose i wrote msgbox(item.recipients.count)
and this gave me 3 in the msgbox. Now how can get the recipients? i can create a loop but what property should i use to extract this ?
iam using O2k3
Shreekanth Murali wrote:
example please
19-Dec-09
Toward Viable CAPTCHA Alternatives
http://www.eggheadcafe.com/tutorial...c-a34cd08623e8/toward-viable-captcha-alt.aspx
Shreekanth Murali
I Found it -->item.recipients.item(i).AddressEntry
Hey I found it
its item.recipients.item(i).AddressEntry
THANKS A LOT FOR YOUR INFORMATION.
20-Dec-09
iam using O2k3
axWebBrowser1.Navigate Auto Page Loader In A Real Browser
http://www.eggheadcafe.com/tutorial...4f-4a6dbf0c2d91/axwebbrowser1navigate-au.aspx
C Eliminate need for "Enable Macro" selection Outlook VBA and Custom Forms 7
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
G VBA Macro Using Outlook 4
