Contacts not syncing due to Outlook Connector
I have Outlook Connector syncing my Hotmail with Outlook 2003. The Inbox and Contacts sync great, but when I try to sync with my smartphone (via Activesync) only the Inbox and calendar sync. I never get an Activesync error...just no contacts move.
I supsect it's Outlook Connector that's causing the problems since it created two Contact folders in Outlook - one from my imported PST file (from my work PC) and one from Hotmail. I don't see any place in Outlook Connector to tell it to not sync my Hotmail Contacts with Outlook (to only sync the Inbox) so there would be only one Contact folder in Outlook. It there such a setting? And I don't see a setting in Activesync to specify which Contacts folder to pick up/sync.
Help please...my smartphone in the meantime has NO contacts on it.
--C
BTW - There is no setting in Outlook that controls which folders sync - Active Sync uses the default pst. There are settings in ActiveSync to control what syncs - you can set it to only sync calendar and inbox or only certain categories.
Yeah...I have clicked on Contacts in Activesync and tried to right click on Settings, but it is greyed out. But it looks like Contacts should sync...still they don't. Argh.
F Contacts folders not syncing with hosted exchange Using Outlook 3
B Contacts just stop syncing, yesterday... Using Outlook 4
J Outlook 2013 Syncing contacts with Android phone - Outlook.com vs Outlook apps Using Outlook.com accounts in Outlook 4
T Not all contacts are syncing Using Outlook.com accounts in Outlook 2
I Outlook Contacts and Calenders not syncing between PC, IPhone, and Windows 8.1 tablet Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
Marcy Outlook and SharePoint 2013 - Syncing Contacts Using Outlook 2
D Outlook 2010 contacts syncing intermittently via Outlook Connector Using Outlook.com accounts in Outlook 2
C Syncing ipad contacts to Outlook 2007 on my PC Using Outlook 3
J iCloud Calendar/Contacts Syncing Hangs At End - aplzod Data Store Not Created Using Outlook 8
N [SOLVED] Live Contacts Not Syncing with Outlook Using Outlook.com accounts in Outlook 8
S Cannot print Contacts Using Outlook 7
L Favorites for People/Contacts? Using Outlook 1
F Moving Contacts to New Profile Using Outlook 0
V Contacts in O365 have changed?? Using Outlook 20
GregS Exporting contacts Using Outlook 1
egarneau Meeting updates with external contacts (GMail) Using Outlook 1
bhamberg Contacts in a category Outlook VBA and Custom Forms 11
