how to enable macro for addin
Ashish
If secuurity level is set to medium (under Tools->Macro->Security) and trust
all installed addins and template is uncheck. Then how to enable macro for
addin programatically. When i open outlook it asks me do u want to
enable/disable macro. If i disable then my addin will not work. To avoid the
message i need to set macro to enable. Please suggest.
K
Ken Slovak - [MVP - Outlook]
Change the security setting. Addin code can't change that or otherwise rogue
code could do it and defeat the security.
"Ashish" <akohli_2004@hotmail.com> wrote in message
news:emoNydEmKHA.1648@TK2MSFTNGP05.phx.gbl...
> trust all installed addins and template is uncheck. Then how to enable
> macro for addin programatically. When i open outlook it asks me do u want
> to enable/disable macro. If i disable then my addin will not work. To
> avoid the message i need to set macro to enable. Please suggest.
Ashish
can i change security setting programatically?
if i change security in outlook and open outlook again then it gives warning
for my add (do u want to enable/disable macro)
how to avoid that message and enable macro
news:u2dvR4EmKHA.4148@TK2MSFTNGP05.phx.gbl...
> rogue code could do it and defeat the security.
K
I just said you can't change the settings in code in your addin.
You need to change the settings before trying to load your addin, and if
necessary put together instructions on what settings are needed by your
users.
news:%23gZ1YQOmKHA.5728@TK2MSFTNGP06.phx.gbl...
> warning for my add (do u want to enable/disable macro)
K Macro won't consistently re-enable Outlook VBA and Custom Forms 2
J OL2003 Macro disables itself - looking for way to automate 'enable' Using Outlook 2
K How do I eliminate the "Enable Macro" selection? Outlook VBA and Custom Forms 16
C Eliminate need for "Enable Macro" selection Outlook VBA and Custom Forms 7
Diane Poremsky Mail-enable Exchange Public Folders Using Outlook 0
R Enable Office 365 Exchange Online Archive Using Outlook 0
R Enable Office 365 Exchange Online Archive Using Outlook 6
Sarge USMC how do I enable hyperlinks in Outlook 2013 Using Outlook 1
A how to install or enable categories in OL 2013 for calendar and contacts Using Outlook 5
D How do I mail-enable a Public Folder Sub-folder in exchnage 2007 using shell ? Exchange Server Administration 0
H enable textboxes and buttons from received email Using Outlook 1
D How To Enable Undo in Outlook 2007 Tasks Using Outlook 2
S Outlook 2010: How do you enable Contacts' Activities to search archive folders Using Outlook 6
J Re-enable the junk mail notification. Using Outlook 6
C How do I enable a link in an e-mail in Outlook 2007? Using Outlook 4
J Enable Sonicwall Outlook VBA and Custom Forms 1
S How do I enable administrator access in Business Contact Manager? BCM (Business Contact Manager) 1
S How to enable scripts to run in a custom form which is forwarded ? Outlook VBA and Custom Forms 1
J Office Ultimate- My outlook doesn't have BCM, how do I enable? BCM (Business Contact Manager) 1
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 14
